Neighbor isuses
Status
Not open for further replies.
   / Neighbor isuses #1
TheMan419
Indiana
New Holland Boomer 24
Sorry about the long story....
Our eastern property line is a county maintained drainage ditch. The neighbors on the otherside, within the last couple years, trenched into the ditch with a drainage line.
Recently we had to have a tree taken down on our property. The arborist who came out to do the work happens to be a family friend. He had not been out to our place in a while so wanted another tour. He noticed where the neighbors had dug their trench into the ditch. He says the trees right on the edge of that trench are going to fall at some point in time. He could not specify a time frame.
His guess is they are not tall enough to hit any of our buildings when they fall.
Of course they are large trees and would take quite a bit of work to clean up when they fall.
So my first issue is do I have a talk with them about this to get it taken care of sooner rather than later? Do I send them a certified letter?
Second issue that I *really* do not want to deal with.... it appears the trench they dug and the tile line they installed is draining a federally protected wetland. I realize bringing that up will result in a neighbor fude of epic proportions. However I am one who is in favor of being a good steward of the land. I generally think wetlands protection is good thing.
So any ideas on how to handle either of those problems?
   / Neighbor isuses #2
Are the trees that might someday fall on his property or the right of way (ROW) in the County maintained ditch? What is your goal? Is it to get the drain tile removed? Or get the trees removed before they fall onto your property? Have you confirmed the opinion of your arborist friend with another source?
If I was on good terms with the neighbor, and wanted to remain that way, I would speak with him in person. I might suggest to him that he might want to check with the County about the possibility of getting some help with the situation "to save him some money".
As far as the federal wetlands issue goes, the definition has changed recently and before I mentioned it to him I might check to see if it would be covered as a wetland under the new rules.
   / Neighbor isuses #3
Get a hold of your county soils map; locate the area and confirm it is wetlands. Then... check with your County Supervisor or zoning office. The more information you have, the better. I'm with you, stewardship of the land is more important than most anything.
   / Neighbor isuses #4
So, to be clear, you're worried about a tree on your neighbor's property that may or may not fall down at some point in the near or distant future, which if/when it does, may or may not even fall on your land. If it does fall on your land, it will cause no damage, only clean up?
That seems like a really easily problem with an even easier solution. Wait for the tree to fall down, and if/when it does, offer to help your neighbor clean it up whether it fell on your land or not.
I live on a private drive. The drive is technically our land, but the neighbors have a right of way. Last month a wind storm came through and knocked over a dead tree on their side of the road. It fell across the road, blocking it, and landed in my woods. I thought about suing them over it, but instead decided to get the tractor out, since they don't have one and I'm always looking for an excuse to use mine, and move the tree so everyone could get out. Then I came back with a chainsaw and log splitter (again, they don't have either and I'm always looking for an excuse to use mine) and cut and split the little bit of good wood and left it for them.
I think the issue of the wetlands can be handled in a similar fashion. It's not your property, so don't even worry about it.
   / Neighbor isuses #5
Excellent advice and neighborly chores!!
   / Neighbor isuses #6
I'd guess that if the trees are on his property there's not much you can do except notify him that since he cut the ditch and weakened their roots and the supporting soil, they're going to fall some day and may hit your buildings, damage a fence, or crush a cow, etc....
Once he's been notified that there's a potential problem, it's no longer an act of God, because he knew about it in advance.
If there's really no danger of them damaging anything on your property, you might just want to let it go.
Will the county notice it the next time they come out and dredge the ditch? Is it in their 50' right of way?
As for draining the wetland, who knows? I thought you had a county person out there last year or two on another drainage issue, or was that someone else? If so, call them and ask. If not, my memory is feeble. :laughing:
   / Neighbor isuses
When the trees fall it will likely be in the ROW and likely in the ditch.
Yes this is the issue i talked to the drainage board about. They did not come out. Just talked to them over the phone.
   / Neighbor isuses #8
Have you ever used the MACOG website? I can't remember if we discussed it or not.
   / Neighbor isuses #9
DO your research ,keep cool and talk to the owner . Nothing beats a cool head these days ! Kevin .
   / Neighbor isuses #10
What's exactly is your neighbors drainage line draining?
Have any pics you can share?
Status
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
