Kitchen Toe Kick Drawers
   / Kitchen Toe Kick Drawers #1
dieselscout80
South Carolina
New Holland TC45DA
Does anyone have a good link to building toe kick drawers? I have seen a couple, but none that struck me as the best way way to do it.
Should the be build before installing the cabinets and the flooring or afterwards?
Does anyone make a push to open drawer slide that will fit in a less than 12" deep cabinet?
Thanks that is the one I have looked at, so far.
   / Kitchen Toe Kick Drawers #4
That's interesting. I've not seen drawers down that low before. Might be handy in a limited space kitchen. With pets, I'd be a bit concerned with dust and fur getting in there.
   / Kitchen Toe Kick Drawers #5
If done right it makes a safe storage for items that need to be hidden
   / Kitchen Toe Kick Drawers #6
I’ve never seen this before. That’s a LOT of extra storage space!
   / Kitchen Toe Kick Drawers #7
I've built a lot of kitchen cabinets, and never done one. Can't see the drawer being tall enough to be worth the bother. Typical "toe kick"....floor to bottom of the cabinet is 3 1/2"-4" inches, then if using a traditional face frame of 1 1/2", the bottom of the cabinet takes up 3/4" of that, and another 3/4" hangs on down.....leaving you 2 3/4-3 1/4" inches to work with. "Euro" style (no face frame) would give you the full 3 1/2-4"...so if I were gonna do this, that would be the route to go.
Something most 'standard' cabinet layouts don't include, IMHO, is enough drawers. Typical door w/drawer at top base cabinets are a huge waste of space in the door section....only so much you can pile on top before the stuff on the bottom is never seen again. :D What you'll find a lot of folks do is go back after the fact and add slide out drawer trays behind the door. Why not simply build drawers to begin with ?
My own kitchen is over 50% drawers. We only used doors under the gas cook top, the sink, and the one inside corner where drawers would have created a useless blind spot.
enhance
The drawer front on the left of the cook top is actually a pull out kitchen trash can holder.
enhance
One other door conceals a spring mounted stand for her Kitchen Aid mixer. It swings up/out to use, then back into the cabinet for storage.
enhance
6 drawers to the left of the sink. Bottom two are extra deep to hold file folders.
enhance
enhance
To the right of the sink base drawers is an 'appliance garage' 16" floor to ceiling cabinet 32" wide that holds all the crap that normally clutters up a counter top. Shelves are on adjustable tracking.
enhance
   / Kitchen Toe Kick Drawers #8
Nice layout. We have a very small kitchen. Our appliance garage is shelving in the basement. :)
   / Kitchen Toe Kick Drawers #9
Thanks. It's a working, farm kitchen, not for show. At times, we're using every inch.
enhance
enhance
   / Kitchen Toe Kick Drawers #10
Yes. I've been following your threads and posts for quite a while now. Good stuff! :thumbsup:
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
Fork and Frame Skid Steer Attachment (A49462)
Fork and Frame...
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
John Deere 825i Gator (A50514)
John Deere 825i...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
