Septic Main Sewer Line
   / Septic Main Sewer Line #12
1/8” per foot is typical for plumbing
150’x1/8” per foot = 18.75” fall
1% is typical for site sewer lines...
1% @ 150’ = 1.5’ or 18” fall
   / Septic Main Sewer Line #13
Re slopes:
You also don't want too steep a slope as the sewage will rush downhill and pile up to create a jamb.
Another precaution is to make clean cuts when joining fittings and even de burring the inside edges.
I like a chopsaw for perfect cuts.
As to de burring, I've seen burrs and rough cuts catch and trap J cloths rags etc that occasionally find their way in there.
   / Septic Main Sewer Line #14
Don't forget about putting in enough cleanouts on long lines either. Snakes are only so long.
   / Septic Main Sewer Line #16
I’m not sure what the distance is but it’s code to have clean outs in it at that distance.
   / Septic Main Sewer Line #17
It's also a good idea to have a cleanout directly outside the house regardless of distance to the septic tank, street hookup, etc... it keeps the goop outside of the house if there's a need to use it.
   / Septic Main Sewer Line #18
I never do. It’s code to have one within 10’ of where the line exists the house on the inside and I usually put the tank within 10’ of the structure so 20’ max distance. My experience is the #1 clog location is the baffle at the pipe exit inside the tank.
   / Septic Main Sewer Line #19
Yes, however, we're talking about long runs in this thread, not 10' from the structure. Regardless, I'd rather have a plumber snake a pipe from outside my house than in my basement.
   / Septic Main Sewer Line #20
Main septic lines are usually required to have 1/8” - 1/4” fall per foot, not 10’.
1/8” - 1/4” fall per 10’ is usually for drainage tile (water).
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55218)
Galvanized...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
