Pressure Testing welds on hydraulic line
   / Pressure Testing welds on hydraulic line #1
robstaples
Gold Member
Near Ann Abor, Michigan
kubota / L39 TLB, BX2680
Looking for direction or recommendations on how to pressure test a 3/4 inch Aluminum schedule 80 pipe with out getting hydraulic oil in a possible leak... making the repair that much harder. Pressure will be limited by over pressure releaf at 1500 psi
The application is rear pto pump feeding front fel snow blower. Pto pump is rated at 2000 psi /20 gal per min. Have had it previous mounted on two tractors using hoses and do not like the messiness of 3/4 hoses for lack of a better term. All tractors have cabs.
So I purchased weldable 3/4 NPT ends to weld on the schedule 80 pipe. The plan was to TIG but the ends heated faster than the pipe and I ended up MIGging them. So the plan is to mount along side cab , tucked close , and have quick connects to be able to leave on year round.
Thought if I had just one small leak at high pressure, I could use that as return line.
For testing , I could individually bobble test with air pressure up to 150 or fill with water and push with a dive tank or welding gas pressure but lots of fittings issues.
Looking for suggestions. This pic shows approx position and end fittings
   / Pressure Testing welds on hydraulic line #2
Aluminium pipe for hydraulic application? Doesn't sound like a good choice to me.
Why not use the proper steel tubing intended for hydraulic hardlines?
   / Pressure Testing welds on hydraulic line #3
What ever tubing or pipe is used do a hydrostatic pressure test if you are worried about leaks,
a hydrostatic pressure test can be done to several thousand PSI with safety.
Any leak will dump the pressure off almost immediately with minimal danger.
Use a hydrostatic test pump do not use high pressure gasses,
many pipe line or pipe fabrication shops will have them and you may be able to borrow or rent one.
Or buy an inexpensive one, even a hydraulic porta power pump will work with water for a while and then can be cleaned lubricated and resealed cheaply.
   / Pressure Testing welds on hydraulic line #4
switch to steel pipe. If you arnt sure of your welding cap 1 end and check with air pressure.
Thanks LouNy, did not know about inexpensive hydro testing. Have one on order. If the aluminum pipe or welds fail badly, I’ll switch to steel or back to carefully routed hose.
   / Pressure Testing welds on hydraulic line #6
Just curious, why did you go aluminum pipe instead of mild steel or s/s hydraulic tubing, it'd be a smaller o/d. I wouldn't use aluminum for hydraulic especially where it's vulnerable to damage, just my thoughts............Mike
   / Pressure Testing welds on hydraulic line #7
Use a pressure washer.
   / Pressure Testing welds on hydraulic line #8
High pressure testing with air is always a bad idea. It compresses to a massive spring & explodes when something fails. A fluid can't compress & only transmits power, but doesn't store it. A hydraulic leak will spray & can pierce skin doing nasty things. But if it ruptures the pressure drops instantly & doesn't explode violently.
A grease gun can hit 8,000-10,000psi on most lever or electric guns. If you properly purge all the air from the lines you shouldn't have to pump that much.
You could use water if you didn't want to contaminate bad welds with petroleum.
As others noted, I'd look at steel instead of aluminum. Stronger, but more importantly easier to weld & less prone to fatigue or stress cracking.
   / Pressure Testing welds on hydraulic line #9
I understood your post to say you want to test the welds for leaks not test the working pressure of the pipe. I’d just hit it with shop air and spray soapy water on it. That pressure is of no danger of exploding and if it holds that leak free it should be fine.
   / Pressure Testing welds on hydraulic line #10
Ya, a few PSI & soapy water will show cracks or holes in the weld. It wouldn't show a really weak point. Makes for a great first test on high pressure stuff. I generally do the soap tes on all my gas lines & my shop air line fittings.
Finished my project with lots of npt joints and No leaks! Tested snow blower , everything worked fine, but pressure only got to 250 psi. Not enough snow load to raise the pressure. I could dead head the pump and test the relief valve, but I am chicken! I may never get that high under normal snow blowing. Bought a 1000psi hydro tester and had more trouble in the test setup. So tested one pipe with two welds and skipped the rest.
All set for more snow.
Ps no holes drilled in Kubota, used existing holes and longer bolts. May add quick connects to front of pipes so Pipes can stay on year round. Not sure.
Come on snow! Thanks all!
   / Pressure Testing welds on hydraulic line #12
Kindly keep white crap in Michigan and play in it.
Don't need any in NY cause snow bunnies can't go sliding down hill on boards due to Emperor Nipples1 closing hills so he can cry in microphone.
Does this mean you live in New York state? Your member information doesn't show your local.
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2016 Hyundai Veloster Hatchback (A59231)
2016 Hyundai...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
