Shibaura tractor (unknown everything)
   / Shibaura tractor (unknown everything) #1
88magilla
Member
Shibaura
I have recently been given a Shibaura tractor S 2000. I致e done hours an hours and hours and hours of foot work on the Internet and have gone to a local tractor supply warehouse and they do not show that this model exist my engine block is C201-500046 4 cylinder diesel and they say that that doesn稚 exist can anybody help me. Thanks.
   / Shibaura tractor (unknown everything) #3
The chassis on the ShibauraST440/445 tractors is very similar if not identical to the Ford/New Holland 1920/2120.
   / Shibaura tractor (unknown everything) #4
How about a little more information to go on?
How many speed transmission
Tire sizes
2wd or 4wd
Pics
If it is a 4 cyl diesel it is at least a 38hp
Here is a Shibaura SD 4000
WoW thanks yes. Sorry never have I Facebook or anything new at all this stuff.
Front tires 6.0-16
Back tires 12.4-20
2wd
Models number s-2000
Chassis number 1752
Engine number c201-500046 4 cylinder
Let me learn how to add pict
We believe it to be from the 1970 or so. Have no idea how to get pictures on the page here. Will continue to try thanks for all the help
   / Shibaura tractor (unknown everything) #7
Where are you located?
Here is how to upload photo
Thanks
I live in Tennessee
   / Shibaura tractor (unknown everything) #10
And you are certain it is a 4 cylinder?
It has four injectors a four glow plugs.93FD385F-D915-45E3-B8F5-7E80AE9D5BB4.jpeg
I have been wrong before. Lol
Thank you !
   / Shibaura tractor (unknown everything) #14
Does it run? What repairs/maintenance do you need to do to it?
It runs fine trying to do maintenance on it it has been sitting for a while. Jurying to find reference material and could not find anything under S 2000 nor with the block numbers. Completely new to this realm so basically starting from scratch
   / Shibaura tractor (unknown everything) #16
Shibaura's have a reputation for being well made tractors. I have had 2 - a 15hp Shibaura and a 40hp New Holland (Made by Shibaura). Both bullet proof.
Step 1 Contact Sheaffer Tractor
Step 2 Change all the Fluids and Filters
Step 3 Power Wash that Beauty
Am I correct 4 cylinder engine.
That’s great thank you for all your time for responding. Felt lost on it all until this site
   / Shibaura tractor (unknown everything) #19
Welcome to the forum!
The label photo shows IHI-Shibaura. This combination shows to have began in the 1950’s. In a quick search I did not find when a name change happened again but did find reference to projects with Ford (later New Holland) and also with Yanmar for the AF series of tractors.
Can you get a number off of your oil filter and cross reference it.
Air filter can probably be matched either by cross reference or careful measurements to length and diameter.
In an external hydraulic filter-cross reference is probably best route. Not all models have an external hydraulic filter and even most imports have a cleanable suction screen that is removable and reusable. A huge caution these screens are located low in the hydraulic reservoir so expect a huge fluid dump if not drained first. Follow the suction hose(s) from the pump, the cover plate will be opposite the suction hose on the differential.
I am sure there is info out there, but if a limited gray brought to the US, it may be difficult to locate.
   / Shibaura tractor (unknown everything) #20
It is for sure a 4 cylinder - just a slightly smaller frame than I would have thought. You will have a nice tractor when it gets a little TLC.
How many speed transmission does it have?'
Does the 3 point hitch work?
Does the PTO work?
Does it have rear hydraulic connections?
Here is some interesting info about Shibaura Shibaura | Tractor & Construction Plant Wiki | Fandom
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
17101 (A55851)
17101 (A55851)
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
Deere 35P (A53317)
Deere 35P (A53317)
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
