Buying Advice First time tractor buyer - dealer proximity advice
   / First time tractor buyer - dealer proximity advice #1
Redbeard81
Port Orchard, WA
Kioti CK2610
Hi All,
I've been lurking these forums for a couple of months while I suffer through analysis paralysis, and after a whole lot of reading (so much good info here!) I've got my heart set on a Kioti CK2610. For the application/specs/price I think it'll be a good fit.
My question is regarding the importance of dealer proximity to my place. There's a dealer 10 miles away that quoted me $20.4k after tax for the tractor, including FEL, 3rd function valve, and filled tires. Unfortunately they're out of inventory and I'm having a hard time getting a real ETA from them.
There's another dealer 90 miles away who quoted me a roughly similar price for an identical setup, and they have one in stock right now. I also don't have a trailer at present; the far dealer is willing to deliver for $250 which didn't seem bad given the distance. If I end up needing warranty work though, I'd have to bother a buddy to haul it to the shop for me and it's quite a distance.
The near dealer keeps making noises about maybe having inventory this month so I'm wondering if I should just be patient since they're basically right up the street.
Any advice would be appreciated. Thanks!
   / First time tractor buyer - dealer proximity advice #2
Maybe ask the local dealer what he thinks. Also check out their service department. Talk to the service managers if they have one.
Also, Welcome to TBN and good luck!
   / First time tractor buyer - dealer proximity advice #3
Welcome to the TBN forum. Unless your in a real hurry, waiting a month for your local dealer to acquire that tractor for his inventory is just fine. Especially during this time of the year, where cold and wet ground conditions typically limit tractor usage anyway. I also would comment, my local Kioti dealer is 1.5 miles away, and in 3.5 years ownership, have never needed his service on my CK4010. So in my particular case, my local dealer has not been relevant.
For me, I purchased a trailer for hauling my tractor, and anything else I need to move.
   / First time tractor buyer - dealer proximity advice #4
I can’t add any Kioti relevant advice here but I can confirm the same notion mentioned above. Having bought my Kubota new, it’s never required warranty work. I like the idea of talking with your local dealer about purchasing elsewhere. Can’t hurt. As a consumer they should understand you have a need for a machine and they’re lack of inventory should not be your problem.
   / First time tractor buyer - dealer proximity advice #5
^^^ And maybe your nearby dealer could do a swap with the other one. That's how my local dealer got mine quickly a couple of years ago.
   / First time tractor buyer - dealer proximity advice #6
I was wondering about that! Car dealers swap and share inventory all the time for customer satisfaction on orders. Just assumed it was not done in the tractor world. I took a long backroad "short cut" this summer to avoid some major Interstate construction, and came across a Kioti dealer with lots of tractor inventory on his lot, while my local dealer, who was only 200 miles away, is sold out and waiting on back orders. So I just assumed no communication between dealers regarding inventory.
   / First time tractor buyer - dealer proximity advice #7
Not familiar with Kioti, how long has dealer been in business.?
In the 70's had JD, CASE and IH (seperate brands back then) within 15 miles. Kubota about 30 miles away.
Now the "local" dealers on opposite end of county about 45 min. drive. Kubota dealer in same location 30 miles away. Kubota/IH in next county about 35 miles away.
If you have a 1st shift factory job, you can get to dealer before closing time.
I prefer to deal with known established brands JD, FORD/NEW HOLLAND, CASE/IH, MASSEY FERGUSON, KUBOTA dealers should have most common repair and maintenance parts in stock.
   / First time tractor buyer - dealer proximity advice #8
I'm not sure how much dealer distance should concern you.
My dealer is 100-ish miles away, but I haven't seen them since I bought my tractor (a Branson) 3.5 years & 360 hours ago.
I don't yet have a tractor-capable trailer, but about once a year I buy something big at an auction 60 miles away and I fetch it using a flatbed trailer rented from a local yard for a little under $100 (which feels like robbery tbh but it's a ton cheaper than buying a trailer I almost never need); if I need to have my dealer look at the tractor, I'd do the same thing.
   / First time tractor buyer - dealer proximity advice #9
:welcome: to TBN.
Do little research both dealers maybe knock and talk check out service departments.
Purchase closer to home will save time $$'s in the long run,but most of all go with your gut feelings.
   / First time tractor buyer - dealer proximity advice #10
I've been with the same dealership for 38+ years. It's a business owned by an old and trusted farming family. I bought my first, brand new, tractor from them in 1982 - Ford 1700 4WD. Twenty seven years later - the dealership had moved from Ford to Kubota. So ..... in 2009 when I wanted a larger tractor - traded the Ford in for a brand new 2009 Kubota M6040. I've needed the dealership once for service on the Kubota. They sent a service technician out to my place( 25 miles ) and did the work here, on site. A hose clamp needed replacing and I didn't have the proper tool.
The current service manager and I get along just dandy. He had his service tech come out and replace this weird-a*sed hose clamp - he and the service tech come out a couple times a year and fish for bass in my lake. Just like the good 'ol days. No money exchanged - just an exchange of favors for service.
   / First time tractor buyer - dealer proximity advice #11
I personally would find others who have experience with the local dealer and see how they check out. If positive I would place my order with the local dealer and wait the month of so.
   / First time tractor buyer - dealer proximity advice #12
Hi All,
I don't know anything about that particular tractor, but the brand has a good rep.
How was it for fit and power when you tried it out? The tryout is always what makes the difference. I remember trying one that had the dash so close it wouldn't fit my knees - although I liked everything else about the tractor. Another one (an MF) had the best seating position I've ever sat on. All the controls just right and comfortable. I took it around the lot for half and hour and bought it.
Check the gearing too. Is the range of ratios good for what you will be doing?
How does it turn with the bucket full?
How easy is it to get on & off?
As for filled tires - do you need that? Alternately you can add wheel weights that do the same thing and are ultimately easier to deal with. Or if you have a real need for more traction and stability just go up one tractor size and you'll get much more of both than loading the rear tires on a smaller machine.
Best way I know of to save serious money on any model tractor is to specify power-shift or power-reverser or both instead of HST. Regardless of transmission type, get as many ranges & gears as you can. You will use them all far more than you think now.
Certainly get a good FEL with a SSQA & a front remote. Then you can add anything else as needed.
In most of the rural US tractor market the dealer is responsible for hauling for warranty work; the owner is responsible for hauling for any non-warranty work. If you think about it, that is popular because it makes the most sense.
rScotty
Lots of good advice, thanks guys. The fit on the CK2610 (for me anyway) is great. I'm 6'4" with size 15 shoes. I'd originally been looking at the Kubota L2501 but with my huge feet the treadle pedal was not comfortable. The Kioti is a bit roomier and has a superior seat, plus little creature comforts like having the loader remote on the right-hand side next to the seat, instead of mounting it forward on the loader itself.
Regarding application, 90% of what I'll be using it for is FEL work. I've got 5 acres and a third of it is covered in low woody brush, deadfall, and old logging debris. My plan was to get a root rake grapple and start clearing stuff out. For the rest of the land I'll be moving a whole lot of topsoil and mulch to put in lawn and garden/food plots, plus gravel for a ~300 yard driveway.
Given that projected application I had no plans for rear implements (at least in the near future) so I was planning to load the tires and add a ballast box. If loading the tires seems like overkill then I could forego it.
   / First time tractor buyer - dealer proximity advice #14
Hi All,
Welcome to the forum sir.
My advice is to use the local or closest dealer. None of us expect our tractors to go back for work but it does happen on occasion. As long as the $$ are similar, go local with your purchase. Don't get sucked into the best internet/volume dealer type of pitch or even just fall for a possibly lower sale price. I would prefer a local dealer that has been around for awhile. It is worth the extra money within reason. Talk to the local dealer and get a time frame for delivery. Dealers can swap/trade vehicles among themselves to get what you want if it is available. As with everything, you have to decide for yourself but supporting a local business is something we should all do more of (as said, within reason).
A dealer ten miles away when you need some gizmo or widget in a hurry is a lot better than a dealer 90 miles away.
Yeah this seems like a good call. I'm planning to be on this land for at least 15-20 years so building a relationship with the local business makes sense. Thanks again for the input and the welcome. :thumbsup:
   / First time tractor buyer - dealer proximity advice #16
Good luck on your purchase and the goal of your long time homestead. Me too. When I moved to the area many years ago, I did not know some 30 years later I would still be there. I'm glad that I did cultivate a few of those long term relationships in buying cars/trucks and equipment.
   / First time tractor buyer - dealer proximity advice #17
300 yard driveway? Your going to want a land plane or box blade to put that together. It’ll make the initial build and maintenance a **** of a lot easier. Their both pricey implements but can be had for okay money with some creativity. I’m actually contemplating a box blade myself. I have a land plane that I use to manage my gravel driveway. Doesn’t take me but a few passes to remove all ruts and potholes. Looks like new when I’m done!
   / First time tractor buyer - dealer proximity advice #18
Regarding your comment on needing a ballast box, just get an attachment like the box blade or land plane, and use that for rear weight. Its just as heavy as a ballast box and a whole lot more useful.
   / First time tractor buyer - dealer proximity advice #19
I agree on using an implement for weight. BTW, although tractors get old and get replaced the same isn't true of implements. They last just about forever. Used box blades cost very little around here and one size fits all. If your dealer doesn't have at least a couple in the weeds behind the shop I'd be surprised. Typical price for a used box blade around here is $250 for a 5 foot wide all manual type. A box blade is close in size to a ballast box, but way more useful. Good for carrying tools, too.
As for filling the tires, you can always do that. Unloading them is quite a bit more difficult and flats are a nightmare. So it makes sense to give it a try without loading the tires at first. Then decide what to add after the implement....if anything.
rScotty
   / First time tractor buyer - dealer proximity advice #20
A lot of times the implement will not be adequate ballast. My tractor calls for something like 750 lbs of ballast and loaded tires. Most implements for my JD2025r wouldn’t weigh enough.
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
