Fluids for an 851
   / Fluids for an 851 #1
antbobeau
851 Powermaster
Hello all, I'm new to the forum and need some advice. I recently purchased a 1959 Ford Powermaster 851 and would like to do a full service to it. What weights and types would be the best to use for the engine, power steering, trans and hydro. Also this unit has a front loader but I haven't had any luck finding a model. It has an external filter which I'm going to change but was wondering if I should change the fluid as well and if so what should I use. I'm gonna attach a picture to help anyone who maybe able to identify the loader. Thanks for any input. Tractor.jpg
   / Fluids for an 851 #2
As a general rule I always change all the fluids on any machine I purchase unless it is new, gives me a starting point for its maintenance. For the engine use what brand and weight suits you best, I run 10W30 in mine but any quality 30 or 40 weight oil will work fine. Power steering gets ATF and the transmission, hydraulics and differential get 134-D which will also work well in your loader. 134-D is available at most all farm stores in 5 gallon buckets and has even been found a few Walmarts if you are looking for it cheap.
   / Fluids for an 851
Thanks for the information.
2016 LT63 Towable Light Tower (A51691)
2016 LT63 Towable...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
More info coming soon! (A50322)
More info coming...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
1272 (A50490)
1272 (A50490)
