TC 30 HYDRO Contaminated
   / TC 30 HYDRO Contaminated
So The good news is that after the change to Tractor supply oil, it did not foam and I ran it pretty hard, The bad news is my splitter and backhoe still have that crap in it and I did the front Diff and pumpkins with it also. Like I stated before I think my splitter had a cylinder full of afterbirth, seems right after that is when I noticed the change in sound of the pumps. The splitter I noticed had the cylinder extended and it sat for like 2 years outside...lots of freezing and cooling..as I get older I find myself not taking care of my stuff like I should...Too much stuff.
I'll tell you something stupid I did once, I had put used motor oil in an empty 5gal hydraulic fluid container. I didn't label it and didn't get over to the recycler with it, so 6 months later I accidentally put about 2 gal of it into the reservoir on a boom lift that I had replaced some hoses on. I kept looking at this fluid as I was pumping it, thinking it looked really dark, then it finally dawned on me what I was doing. Fortunately I didn't start the machine, so I only had to pump out the reservoir.
That thought has crossed my mind but I checked and I used the correct bucket, I did one time start to dump a mix of chainsaw mix in my washer fluid container in my truck, good thing i got a whiff of it before a lot went in.
   / TC 30 HYDRO Contaminated #13
I made a hydraulic fitting that fits onto the return hose of an implement and is just an open fitting, so when I want to purge the oil from the hoses on that implement I put this adapter on and dump the oil into a bucket until I see the oil change color. I have a post pounder that holds a lot of oil in the hoses and large cylinder, and I share it with a neighbor who has a JD. I didn't want to mix hydraulic fluid so I always purge it after we use it on his tractor.
Good idea, My Backhoe runs off the rear remote, Just need to figure out the return line, I do not think I could dead head any circuit by doing it that way, The relief valve is in the remote so should be no issues.
2018 International DuraStar 4300 TMA Attenuator Truck (A52377)
2018 International...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
Electric Mobility Scooter (A51694)
Electric Mobility...
