Filters... FILters.... FILTERS!!!!!
   / Filters... FILters.... FILTERS!!!!! #11
Just bought oil and filter for 200 hour on mx. Dealer told me because of warranty issues, you must use oem.
That sounds like lawyer talk to me but, i bought 2 gallons of kubota motor oil and their filter, $55.
I did see some guy on u tube cut open a Fram and kubota oil filter and there was a significant difference. Question is, does it make any difference?
I wouldn't take it as lawyer talk. I mean, the brands and the dealers need some insurance that the proper filters and fluids are used.
Who knows what people would throw at the tractor, then it failed and they try to file a warranty claim? Like using the wrong hydraulic oil in tractors with clutch packs or wet brakes, can ruin those in no time.
Over here, and in most countries actually, you can't even service your vehicle (car, truck, tractor, whatever) yourself if it still has warranty, otherwise, warranty is voided.
The service is done at the dealer and the warranty book that comes with the vehicle is signed by the dealer, proving the service was done there.
   / Filters... FILters.... FILTERS!!!!! #12
the only filter on a branson you have to( or should use) an OEM filter for is your transmission hydraulic filter( this goes for both filters if you have HSt transmission)
the reason we tell you guys this and the reason we are told to tell you guys this is for a specific reason and that's due to how the filter is designed, there is a bypass/flowback valve in the bottom of the filter should this filter ever get clogged up the bypass/flow back valve will open allowing hydraulic fluid to flow through the system, if you don't have a filter with this valve in the bottom( as far as i know no one makes this other than Branson if any one knows of a filter brand that does this as well please let me know). it can cause the hydraulic pumps to run dry and damage them or in a worst case scenario completely burn them up.
   / Filters... FILters.... FILTERS!!!!! #13
My lawyer talk comment was, in my case, the kubota parts guy couldnt/wouldn't give me a straight answer. knew he couldn't, i was just messin with him. I asked, what if I use Fram, is the warranty voided. Again, he couldn't give me a simple straight answer.
To me, that's lawyer talk, they plant doubt then leverage it. Not all lawyers.
Well, I would think a manufacturer would have to prove the filter you used caused the damage. It would be a gamble for sure. And could potentially be expensive if you lost. So, is the few dollars in savings on after market filters worth the risk? Prolly not. I just find it annoying that you have to buy your filters from a dealer. B.
   / Filters... FILters.... FILTERS!!!!! #15
I hate that too and I hate knowing I'm getting ripped off. My hydraulic filter is $100 and it's made in China, even though it has the genuine Kubota sticker on it and I bought it at the Kubota dealer. I KNOW this is a rip off but I'm not going to chance putting a non OEM filter for the hydraulic system or the HST system because if there is a problem with those systems it's going to be a very expensive repair.
   / Filters... FILters.... FILTERS!!!!! #16
I guess we can console ourselves with the thought that at least we don't have to change them very often.
I'll just get the OEM ones myself. One less thing to be worried about with possible consequences.
   / Filters... FILters.... FILTERS!!!!! #17
Kubota parts made in China will be the same quality as Kubota parts made anywhere else. Chinese factories make parts to the quality the buyer or owner demands and inspects for. A multinational like Kubota often will set up their own factory and always oversee it so they know it's done to their specs.
But $100! I'll stop complaining about $47 for the Branson hydraulic filter.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2015 Rogator RG1300B Spreader/Sprayer (A50657)
2015 Rogator...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Axle (A50860)
Axle (A50860)
King Kutter CV-G-1-C-YK 3-Point One Row Cultivator (A50860)
King Kutter...
