Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #16,971
Did it come like that, or is it OldPath installed? My old Fransgard had a ferrule to keep it from coming undone. The best way to keep from doing what I did though, is to avoid pulling with the tractor when at the end of the cable. It seems like I may have learned that lesson once before with one of my old winches... :rolleyes:
Yeah that's original 07 Fransgard winch, all it it is is a 3/4"x1/2" 1"-ish steel block with 1/4"set screw and 8mm hole going through it for cable. But the method of getting to the spool has been upgraded and modified, sometimes I wonder what design engineers of equipment are thinking when they make stuff.....
   / Tractors and wood! Show your pics #16,972
I'm not sure what year mine was, but it was "old" when I bought it in 2002. It was a challenge to find one used... back then I subscribed to "Uncle Henry's" so when they released it on Thursdays I could get online and check it at about 3:00 AM. I was working in Gorham NH that week but took the day off and drove to Brunswick (ME) to buy it.
   / Tractors and wood! Show your pics #16,973
No mostly the Black Hills, thats why I had to leave....
Well the Black hills are in South Dakota... sounds like more fake news...
   / Tractors and wood! Show your pics #16,974
You are probably right, now that team "sniff and blow" has taken over, there will be plenty of fake news to watch! lol
SR
Heck, I quit watching the news, too depressing and nobody does anything about anything anyway!
   / Tractors and wood! Show your pics #16,975
Most stories I can't do anything about either...
Looking for IBC totes and no deals here...
   / Tractors and wood! Show your pics #16,976
You have to drive up to Oregon and see Molalla1
   / Tractors and wood! Show your pics #16,977
I have a small steel block with set screw on my spool it keeps cable from coming off spool as long as that set screw is tight.
The wire rope on my Wallenstein is very easy to replace and it's held on the drum with a couple bolts, so you can't pull it all out and off it.
Easy to get to too...
But in both cases, you are supposed to leave at least several wraps on the drum when pulling a load.
   / Tractors and wood! Show your pics #16,978
That's true, but my point is, you can't pull it off of/out of, the drum and if needed, it's easy to replace...
SR
   / Tractors and wood! Show your pics #16,980
If you have a extras i'd be much obliged to take a few off your hands
I'm not home right now I'm at my place at the coast. I'll check with them when I get back, about a week and see . . .
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
35176 (A53424)
35176 (A53424)
