Coolant leak/puddle after plugging in block heater on Ck2610
   / Coolant leak/puddle after plugging in block heater on Ck2610 #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I had a factory bloc heater installed when I bought the CK2610. Tried it out for the first time today. Plugged it in for 1/2 hour, came back to a coolant puddle on the floor. Investigation revealed some seapage around the main rad hose going into the bloc heater on top, which I tightened.
I am wondering if the bloc heater could be defective, could it be getting too hot and causing a leak? My coolant level sits at low mark right now, 29 hrs on the tractor. I may have been seeping all along, but the coolant evaporated and did not puddle. What puzzles me is how plugging in the bloc heater revealed the leak so well. Anyone have a similar experience?
   / Coolant leak/puddle after plugging in block heater on Ck2610 #2
You're probably correct in that you've had the leak the whole time.
Heating the coolant causes it to expand and create pressure, which is being released at the hose clamp.
Patrick
Patrick
It would seem so. I snugged up the top of block rad hose clamp, and no more visible leaks after the "heater bloc on" pressure test :)
I will keep an eye on it, as it is now on "low" level. I'll have the dealer top it up for free if i decide to get my 50 hr service there.
1676 (A54756)
1676 (A54756)
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
Kubota diesel tub cart 2015 (A55787)
Kubota diesel tub...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2020 FREIGHTLINER M2 106 BOX TRUCK (A54607)
2020 FREIGHTLINER...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
