MF 1240 Safety switches and relay
   / MF 1240 Safety switches and relay #1
Kenzepp
Virginia
Massy Ferguson 1240
Purchased my MF 1240 4 WD with manual transmission back in 1997, new. Great compact tractor and had no major problems until recently. Engine would not turn over! Checked battery and determined that starter might be the problem, replaced starter and ignition switch and problem continues. Not much of a mechanic but can follow wiring diagrams. Unfortunately, don't have a good WD and am specifically looking at locations and wiring for safety switches. Suspect that or safety relay.
Question 1: Where is the safety relay located on this tractor?
Question 2: Is there an easy way to bypass all the safety (interlock) switches? Appreciate any help.....thanks
   / MF 1240 Safety switches and relay #2
I have a MF1250 compact, also having a problem....found a relay behind the right side inside dash and my problem is it will not turn off via the key, I have to remove the right side engine compartment cover and push in what I call the solenoid mounted midway top to bottom and front to rear. 2 wires. How do I know if it's the ign.switch, relay, or solenoid that is the problem?
   / MF 1240 Safety switches and relay #3
My belt was loose, enough that it would not charge the battery, or start. New battery , new starter, new ignition switch. Belt was just loose enough.
   / MF 1240 Safety switches and relay #4
WD
   / MF 1240 Safety switches and relay #5
More wd + pics.
First 6 of attch of 1st reply are wd for prior to j s/n, and last 4 are std.
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
Ammco Brake Machine (A53424)
Ammco Brake...
MISC WRENCHES (A53843)
