Question: Motor Oil for Backhoe Fluid?
   / Question: Motor Oil for Backhoe Fluid? #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
My 1980's backhoe specifies 303 UTF. I use J20C, the later multigrade UTF.
I just discovered the fluid must have gotten water in it, its creamy foam and squeals easily. Its time to flush and replace it.
I have a few 2 gallon jugs of NAPA's prior spec 15w40 diesel oil, made obsolete by recent smog gear. It was on closeout real cheap and my 40 year old tractors don't care.
Is this diesel rated motor oil suitable to flush the backhoe's hydraulics, and is it harmless run it for the season before buying more J20C?
I also have an unopened gallon of Dexron III ATF. Suitable for flushing oil? For blending?
I'm assuming all these fluids are nearly identical, with likely extreme pressure additive in the UTF that isn't crucial for a backhoe, and other magic in the diesel oil that's also not relevant. I guess the question is whether there's anything harmful.
   / Question: Motor Oil for Backhoe Fluid? #2
my white lawn tractor uses 20w50 motor oil for the hst transmission. do with that what you will
   / Question: Motor Oil for Backhoe Fluid? #3
I have one hydraulic system from the 70's that specifies SAE 30 wt motor oil so I would think you could. HOWEVER, I would be concerned about the compatibility of the oils. I use the same oil to flush a system that it uses so I don't have to worry about the oils being compatible with each other.
... I would be concerned about the compatibility of the oils. I use the same oil to flush a system that it uses so I don't have to worry about the oils being compatible ...
Yeah that's my concern.
I was surprised after a little research to see that some varieties of UTF sold in Britain and Australia are universal, the same product is recommended for motor oil as well as hydraulic and transmission fluid.
   / Question: Motor Oil for Backhoe Fluid? #5
Bush hog 750 3pt backhoe w/pto pump recommends 30w non detergent engine oil.
   / Question: Motor Oil for Backhoe Fluid? #7
I would have no hesitation using 15w40 in an old backhoe. Or the ATF, or a mix for that matter.
Think about the moving parts. Gear pump....valve, cylinders.....thats pretty much it.
Transmissions have gear pumps, hydraulic pistons, spool valves, etc.
Engines have gear pumps....seals...sometimes little pistons for tensioners, etc.
A simple old hydraulic system with a pump, valve, and cylinders is about the LEAST demanding application you can ask of an oil.
Thanks. That was my reasoning. Hydraulic oil mostly just pushes cylinder pistons, an undemanding application. But I wondered if anyone would comment on incompatibility between the various fluids. So far, I haven't seen anything that discourages me from going ahead with this.
i need to put something fresh in there. And until I've had my covid shots it seems like a good idea to use materials already on hand instead of going shopping.
   / Question: Motor Oil for Backhoe Fluid? #9
In a hydraulic system I wouldn’t attempt using any oil that’s not approved, I actually know someone that changed the oil and used motor oil instead and very soon wound up having to buy a new pump.
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
28013 (A50322)
28013 (A50322)
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
