Good quality asphalt driveway crack filler
/ Good quality asphalt driveway crack filler #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
Looking for a good quality product to use for filling cracks in my new asphalt driveway? The simple stuff at the big box stores (in a caulk tube or pourable) never seems to have the coverage or elasticity to deal with temp cycles here in MN. I apply it in the summer/fall and when winter comes the cracks open up and it is essentially useless. Would like a product similar to the thick, rubbery stuff the county puts on the highways, but I understand that is a hot mix that isn't easy to do for a homeowner. My main concern is to keep water out during the spring freeze/thaw stuff that is so bad for damaging driveways.
Rob
/ Good quality asphalt driveway crack filler #2
Check with a reputable local company that does asphalt driveways. They should be able to suggest something.
/ Good quality asphalt driveway crack filler #3
you shouldnt have cracks in a new driveway. call back the company that did the work and have them do the repair.
/ Good quality asphalt driveway crack filler #4
The junk you get at Lowes is useless. Every crack I have filled with it is open again.
The next time I will rig something to use hot tar.
/ Good quality asphalt driveway crack filler #5
I've never found anything to beat hot tar. You can often rent a pot locally. If it is new and has cracks, I would call the contractor.
All the best,
Peter
/ Good quality asphalt driveway crack filler #6
Lowes has 50# blocks of rubber designed for filling cracks in driveways, especially larger cracks. and stays intact for a long time, years.
Simply get a turkey fryer and a Nesco sized pan, break down and melt the rubber to a good flowing temperature. and fill in the cracks using a pouring applicator designed for that. We sealed all large cracks in our 1200' driveway and maybe 1000 square feet of alligator type cracks 6 years ago for about $400 worth of rubber. $70 for a cooker, a used Nesco kettle and a $70 applicator kettle. Can't forget a weedburner for heating the road where tar will be applied.
My wife followed after me with a ice scraper to massage the tar into the fine cracks. After the cracks showed again we went over most cracks again a few weeks ago but it only took and 4 bricks of rubber. i like it.
A contractor did half the cracks across the driveway for $450 6 years ago is why we decided to try it ourselves. It took a day to go over it all again and touch it up nice. Takes a lot less rubber the second time around.
/ Good quality asphalt driveway crack filler #7
Thats what I had in mind. Did not know Lowes had the rubber.
Thanks.
Thanks. You don't happen to have a link to those rubber blocks, do you? I couldn't locate any on the Lowes site.
Rob
It's an overlay. The cracks are expected. They are not significant but I want to stay on top of them.
Thanks!
OK, so when I look for a hot tar 'applicator kettle' I mainly find the big trailers and heavy equipment. I assume you're referring to something handheld. Hate to be naive here, but what are you referring to with 'Nesco kettle' and 'applicator kettle'?
Thanks,
Rob
Ah, something like this would be the applicator 'kettle'?
Or this:
This one looks slick too. More expensive but would be a back saver.
Still not certain what to use for heating on the propane burner. Anyone have ideas on a heavy metal pot?
Rob
/ Good quality asphalt driveway crack filler #16
A local neighbor has a short half moon asphalt driveway. His pot full of tar ignited. I think that's when the fun began.
I think I located everything I need for this. Thanks for the tips! Will be nice to have actual rubberized hot sealant to fill the cracks.
And for the "it shouldn't happen on a new driveway" folks:
This is three lateral cracks on a 600' driveway of 3" asphalt overlay on top of the old asphalt. We had over a week of -25*F low temps recently that contracted things enough to cause these cracks. They occurred in the narrow (10' wide) section of the driveway that is elevated above the surrounding terrain, where the cold was most easily able to affect it. It was expected to happen sooner than later.
Rob
/ Good quality asphalt driveway crack filler #18
Thanks for explaining why you have cracks in a new paving job. Did they use geotextile under the top layer? Using one helps not to transmit stress from one asphalt layer to another, reducing cracking.
As an alternative to hot tar, there is this crack filler from Lowe's which you put in with a propane torch.
All the best,
Peter
/ Good quality asphalt driveway crack filler #19
My driveway does the same thing, it gets really cold and it contracts and they open up.
All the best,
Peter
Thanks for the alternate idea. However, I have the equipment and supplies coming now that should allow me to do proper hot pour crack filling and last me for years. The torch-applied version looks quick & easy but I don't know if it would get into the cracks as well. Anyway, too late to change.
Rob
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
3650 (A47477)
3650 (A47477)
WATER TRAILER (A58214)
