GC2400 DL100 loader replacing hairpin clips with clevis pins
   / GC2400 DL100 loader replacing hairpin clips with clevis pins #1
Dmacleo
Etna, Maine
2010 MF GC2400 Owner, 2012 MF1532 User
seems the forum upgrades lost some items, cannot find the post (iirc in the what have you done thread) about replacing the haipins with clevis pins that I had replied to.
I have replaced all hairpins on whole tractor with clevis EXCEPT the 2 that hold the DL100 legs up onto loader arms.
the reason I have not just drilled and replaced is there is not a lot of "meat" on the pin welded to arms that the clip goes into.
I was wondering if anyone has drilled it to accept a 3/16 clevis and if they ran into any long term issues from vibration.
edit: I typed clevis pin but MEANT lynch pin.
these
   / GC2400 DL100 loader replacing hairpin clips with clevis pins #2
I don't recall seeing those previous posts. I will say (just for my 2 cents worth) you must be desperate for something to do to be changing out all those pins. Do you think there is some sort of problem with the factory pins ?
those hairpin clips are a pain compared to actual lynch pins and, as I have found on a GTC1710 and GC2310 those hairpin clips can easily break. twice we have had a small rock bounce onto the bush hog and jam into lift arm snapping pin. lynch pin does not break. so I decided to do it on my personal 2400
I replaced everything with these.
   / GC2400 DL100 loader replacing hairpin clips with clevis pins #6
Odd... I never seem to have a problem with hair pins, but have lost several lynch pins over time (or lynch pin fairy sneaks on to property and steals then)...
Dale
   / GC2400 DL100 loader replacing hairpin clips with clevis pins #7
these
Yeh, that was me that did that. Yeh, it worked out great, have no problems with them.
thanks, I took a chance and carefully drilled those 2 to 3/16 (then wiggled bit a little for clearance) and will monitor. if I see ny issues will prob just sleeve it (vs cut off and reweld whole pin and pad) and extend it 1/2 inch.
   / GC2400 DL100 loader replacing hairpin clips with clevis pins #9
Cool.
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
