Hydraulic line sleeve/abrasion protection : what do you use?
   / Hydraulic line sleeve/abrasion protection : what do you use? #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I now have a few implements with hydraulic hoses, with some obvious abrasion points. I can reduce most of it with creative tiewrap use, but there will still be some areas that will be more prone to rubbing/wear and tear. What do you use to protect your hoses? Nylon tube sleeve, plastic spiral wrap, velcro sleeves?
I would rather get a solution that allows me to protect the hoses still attached (less mess), but will consider all options.
The loader hoses on my Kioti have a nice nylon velcro sleeve, but it is a bit low on coverage and is already fraying. Ideally I would find another source and overlap the oem sleeve (basically warps all 4 hoses) with another nylon velcro sleeve, increasing coverage and doubling up on the "fraying point".
   / Hydraulic line sleeve/abrasion protection : what do you use? #2
I use the heavy duty plastic spiral wrap you can put it on with out taking the hoses off. It can be a pain in the butt to do sometimes...
   / Hydraulic line sleeve/abrasion protection : what do you use? #3
   / Hydraulic line sleeve/abrasion protection : what do you use? #4
For an area where the three point hydraulic hoses come up over the back -behind the seat - and were exposed to slight wear, I used a foam pipe insulator sleeve. This will do nothing to fix any abrasions but can serve to protect them a bit from getting the abrasions. Where one of those hoses was getting hooked up on the gannon box, when it was raised on a certain angle to engage the scarifiers, I used a bungie core to keep it out of the way- likely I need to rethink why it was getting hooked up in the first place.
   / Hydraulic line sleeve/abrasion protection : what do you use? #6
I used the heavy duty plastic spiral wrap. It IS a PITA to get started. After that it's just a matter of finger strength. It does do a good job and should last forever. I used it on my grapple hoses and my rear blade hoses.
   / Hydraulic line sleeve/abrasion protection : what do you use? #7
ON my Log splitter I used nylon sleeve.... Mainly for protection from UV and aging because it sits out in weather...
Get a length longer than you think you will need, bends in hose take up 3-6 inches of sleeve at each bend....
   / Hydraulic line sleeve/abrasion protection : what do you use? #8
This looks like a good fit for me, and the price is reasonable too (although I will brace for the standard Canadian upcharge).
Princess Auto sells it in black for $45 for 25' (1" diameter). They also sells the sleeve type for cheaper if you can disconnect the hose.
Are the edges of the spiral rounded? Unclear from the picture. I have seen some that have square edges (looks like someone just spiralled a pipe), they can actually chaffe the hose.
   / Hydraulic line sleeve/abrasion protection : what do you use? #10
The plastic one I posted, does have rounded edges. They also sell it in different sizes and colors...no way it would chaffee anything. It’s easy enough to cut to length, but I would recommend cutting it to length after it’s on.
1999 Peterbilt 379 Tandem Axle Road Tractor (A55272)
1999 Peterbilt 379...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58216)
FOUR WAY BLADE...
6' PULVERIZER, 3PT (A52708)
6' PULVERIZER, 3PT...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
20FT X 20FT ALL STEEL CARPORT (A58214)
20FT X 20FT ALL...
17345 (A56859)
17345 (A56859)
