BX fuel tank inspection plate
   / BX fuel tank inspection plate #1
1jogger
southern cal
kubota bx24
After multiple filter and fuel pump changes I expected to find material blocking the fuel outlet inside my tank but.... my tank was clean.
I think I have an occasionally collapsing or pinched fuel line (it's 15 years old) so the back half of tractor has to come off which I was trying to avoid.
The plate comes from "Boyd welding" in Florida for $38 plus shipping, SKU44033. I carefully redrilled the holes in the tank a little larger than suggested using metal plate as a template and it worked perfectly.
Hope this helps others, it's a great well made product
   / BX fuel tank inspection plate #2
I thought I replied to this post. Maybe a duplicate of one posted at OTT?
Why did you install an inspection plate when you found the tank clean to begin with?
I am starting to get the feeling this is a back door approach to promoting the product...:(
I posted this on OTT as well because this seemed to be a common problem with these tractors.
I could only find 2 other inspection plates both marine applications, one from Australia (and not available here) the other was too pricey.
As I said before, I found the tank clean AFTER I installed the inspection plate.
No back door approach.
I've gotten a lot of great information from these sites and wanted to share some info that's all.
   / BX fuel tank inspection plate #4
Thanks for the clarification.
Since you mentioned first that the tank was clean, and then moved on to the inspection plate, I thought you meant you installed the plate after finding the tank was clean...;)
   / BX fuel tank inspection plate #5
On my system it was that 5 (?) ported thingy...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
Deere 316GR (A50123)
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
