2014 Kioti KL401 loader hydraulic cylinder Rebuild Kit?
   / 2014 Kioti KL401 loader hydraulic cylinder Rebuild Kit? #1
liberty2701
Lakes region,NH
Kioti Dk50se hst
Where can I find a cylinder rebuild kit? The dealer only sells new cylinders.
   / 2014 Kioti KL401 loader hydraulic cylinder Rebuild Kit? #2
It's hard to tell from the picture but I'm pretty sure the cap just threads in.
Once you got it all apart, just take the seals individually to an hydraulic shop. Quite often it's cheaper to get the seals individually, instead of getting a rebuild kit.
I updated the post. The cap is threaded on.
   / 2014 Kioti KL401 loader hydraulic cylinder Rebuild Kit? #4
Liberty, I’m just down the road from you, bring in some samples.
Your link did not work. Is it Curtis Hydraulics?
   / 2014 Kioti KL401 loader hydraulic cylinder Rebuild Kit? #7
Go ahead and do both (or all four) cylinders at the same time. I was advised to do the same by the shop that rebuilt mine and chose not to. I was back in 6 weeks like they said with the other two. The new seals hold more pressure/ put more pressure on the older seals.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
