International DT 360 connecting rods
   / International DT 360 connecting rods #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
So, I screwed up and had all.the pistons removed from the rods before I noticed the flat spot up top...dies anybody know whether this is supposed to be in n the cam side or the other way?
As you can see, they're otherwise symmetrical so, I'm pretty sure they'll go in the wrong way just fine if I try it...
   / International DT 360 connecting rods #2
Did you ever find out I just did the same mistake
I put them all in facing the same way but, I can't remember which way that was. The truck is running great so either it doesn't matter or I won the coin toss.
   / International DT 360 connecting rods #4
Dam I’m in the same boat so I guess I will do the same I’ll put them to the cam side
   / International DT 360 connecting rods #5
Thank you
STORAGE FEES (A51222)
2006 International 4400 LP Ambulance (A50323)
2006 International...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
