John deere 5500 wont go in park
   / John deere 5500 wont go in park #1
Winnie7310
John deere 5500
Need help bought tractor told all good..won't go in park synchronize transmission. I also notice level pops put of snail. All other gears are perfect. Not feeling safe without park
   / John deere 5500 wont go in park #2
Sounds like the linkage may be out of adjustment.
How would that be adjusted?
   / John deere 5500 wont go in park #4
Not sure since I got rid of my 5310 I don't have a tech manual any longer. It may require splitting if there's not an access cover. After thinking about it I'm not sure the sync shuttle has external linkages. It may all be internal.
Oh boy big project guess I got taken again. Thank you!
   / John deere 5500 wont go in park #6
Park pawl could also be broken. This can happen if operator put the tractor in park when it is still moving/rolling.
How would this be fixed?
   / John deere 5500 wont go in park #8
Tractor split.
If you have older parts NLA
There is newer kit $900
Tractor split.
If you have older parts NLA View attachment 692643There is newer kit $900View attachment 692644
Think we found problem today. So my lever won't go over to park. It's like something is stopping it. Took shifter out checked pins than took top off and found the long rod that shift in is locking the rod so it won't mover all the way over to park. A little ball popped out what is that piece called. When I moved the rod it felt like it was stuck so I rolled the rod felt a click and it released it to extend fully. Could someone messed it it and that little piece is backwards.
I can't find specs on it
   / John deere 5500 wont go in park #10
What transmission do you have? There are three.
Is it the range lever that puts it in park?
It has 2 lever 1 puts in park 1 2 3
Other snail ABC
Both on floor says synchronize transmission
   / John deere 5500 wont go in park #14
Per jd110, the gear shift lever is what engages park.
Drawings are gear shift lever and internal parts. What part did you think might be backwards? Did you find where the ball goes?View attachment 693019View attachment 693020
AEREATOR (A58214)
AEREATOR (A58214)
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
2006 JLG E400AJPN ELECTRIC BOOM LIFT (A60429)
2006 JLG E400AJPN...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
