Pothole theory
   / Pothole theory #11
If I used loose stone on my driveway (only one "flat" spot) my truck tires would never get any traction. There's a reason it's called "Hillsville"... I've seen others with flat driveways with loose stone, too noisy for me. YMMV.
   / Pothole theory #12
There is a simple way to tell if you have fixed a pothole correctly...if fixed correctly a pothole won't come back...
stir it up, fill it in, pack it down and make sure water runs off the area...
   / Pothole theory #13
Haha yes it is quite noisy! It's a helpful driveway alarm, at least when I am working outside. Hear a nice loud rumble-whoosh as any visitors arrive. I do feather my pedal a bit when driving my truck up the drive... easy to spin the tires.
   / Pothole theory #14
Potholes develop because water can not escape. The road surface should be higher than the surrounding dirt and it needs to be trenched to move the water away.
On my ranch, my grandfather understood what it takes to make a good road. He raised the road bed up about 10 feet from the surrounding land and made good ditches the entire way. I have never seen a pot hole on that road in my life. The water never sits on the road and it's always in the ditch. Good roads have good ditches.
You can kinda see what I'm talking about, the only pictures I have on my phone at the moment.
   / Pothole theory #15
This^^^^
Potholes are the symptom of an underlying problem (poor drainage). Tackling the symptom, without addressing the underlying problem, is a fools errand.
   / Pothole theory #16
There is an old saying about driveways.
The three most important things about driveways are: DITCHES...DITCHES...DITCHES!
   / Pothole theory #19
So all I need to do is have the drive 10' higher, and have good drainage?
I'd go 15 feet up, just to be safe. Should only take about a couple hundred dozer hours and 50-60 tri-axle dump loads of fill. Easy weekend job. I mean, you don't want any pot holes, right?
197711 (A51244)
197711 (A51244)
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2012 John Deere Z925A 60in Zero Turn Commercial Mower (A52377)
2012 John Deere...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
