Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #17,681
That gsa/oil/tool kit sure looks nifty, are you a professional tree cutter?
The tree looked dead and dry, but I didn't notice any rot.
   / Tractors and wood! Show your pics #17,682
That’s a husky can I was shown it works really well being it’s everything in one and has enough storage in the pocket to fit two 32’s or 36’s chains. We are a full service company from commercial thinning with harvester forwarder combo to clear cut and hauling.
All that color in the butts like what the saw is on in the one photo that’s all rot.
   / Tractors and wood! Show your pics #17,683
Before I fix up the truck.
   / Tractors and wood! Show your pics #17,684
Wood pics.
   / Tractors and wood! Show your pics #17,685
I was going to post this in the “Safety” forums but it seems to fit better in this thread.
I can’t tell exactly what happened. However, AWOL member “OldPath” commented several times of the need for stops with your bucket forks, to keep logs from rolling up over the top.
Be careful out there, if you find you are getting tired call it a day.
Sure is a good reminder. One advantage of a grapple is there is so much less chance of something like that happening.
I often wonder if making do with what you have pushes the envelope sometimes, especially with guys like me who are inexperienced. Buying the right tool can seem expensive until someone gets hurt/killed or a machine is damaged. But I have seen "experienced" folks take risks I would never take because they have never had an accident...yet.
Prayers for the family.
   / Tractors and wood! Show your pics #17,686
Had to fall a couple of trees last week that were too close to my private power line. Both Douglas Fir. One was 24" at the butt and the other was 16". The bigger tree went exactly where planned but the second one had a slight back lean towards the power line and concerned me a bit so I had the wedges ready to go and after making the back cut I turned around to get the wedges and when I turned back the tree had squatted back. I couldn't get the wedges started so panic set in and I had to run back through thick bush and ever a frozen creek to get to the SxS, to get my chain and come along. I pulled the tree back enough to get the wedges started and then all went as originally planned. I thought I was going to have a friggen heart attack running back to the SxS but I finally got to settle down after the tree was on the ground. Then back to taking out several smaller ones. I learned a lesson that day. Don't pull the saw out until I get the wedges started.
This was the best day for this work, as the power to out area was shut down for a few hours while the power company did some maintenance work. Figured that would be safer than taking this on when the line was live.
I don't like to take chances with live power lines because of an incident with my son, years ago. He works for a tree business that trims trees away from power lines and one day I got a call from a hospital telling me that my son was in emergency and had been helicoptered there. Later I found out he dropped a tree on a 240,000V transmission line and was electrocuted He is very lucky to be alive.
   / Tractors and wood! Show your pics #17,687
One trick that can help with back leaners like that is to put your back cut in first and tighten up a wedge then put your face in. It’s basically the same way we put jacks in.
   / Tractors and wood! Show your pics #17,688
Thanks for the tip. Most of the trees I drop are smaller and usually don't have enough room for a wedge but this technique might work for those. I'll have to give it try when I get back to getting firewood.
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
Ford 655C 2WD Cab Backhoe (A55302)
Ford 655C 2WD Cab...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2004 INTERNATIONAL PAYSTAR 5600I DAYCAB (A55745)
2004 INTERNATIONAL...
2015 Nissan Rogue SUV (A55758)
2015 Nissan Rogue...
