Ethanol gas evidence
   / Ethanol gas evidence #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I bought a walk behind mower yesterday and started messing with it today.
It ran last season and was left with ordinary pump gas with 10% ethanol.
Not only the bad gas, and cleaning the carb bowl, main jet, float, etc.
Look at this nice surprise from the plugged up fuel line.
That’s a longer drill bit it used to go through it ramrod style. This came out the opposite end on the first pass.
   / Ethanol gas evidence #3
We all need to put fuel stabilizer in the tank before you shut it down for the season and run it through the whole fuel system.. Gasoline fuels need this weather it has ethanol in it or not. o_O
   / Ethanol gas evidence #6
Bought myself a heated ultrasonic bath cleaner I keep filled with Berryman's B12 Carb cleaner. 30 minutes in that cleans everything. Won't clean goopy hoses though.
Good enough for Mustie (on You-Tube)_, good enough for me.
   / Ethanol gas evidence #7
All gasoline fuels are made or refined as an expendable product and its always been that way. That means they have a limited shelf life and as soon as they come out of the pipe line or exposed to oxygen they deteriorate. The only way to extend this is to keep it very cool, have no oxygen for it to mix with, or add a stabilizing chemical to it. One of these options is pretty easy to do.
   / Ethanol gas evidence #9
What is that stuff? Did it just melt the fuel line?
My goodness. I have to admit I’ve left fuel in mowers over the winter but nothing like that ever happened. Ever.
MoKelly
   / Ethanol gas evidence #10
How old is that mower?
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
TIRE MOUNTING AIR MACHINE (A53843)
TIRE MOUNTING AIR...
