ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 12,480
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
What will seafoam do? But I only use it as a fuel stabilizer.
Sea Foam is specially formulated to safely and slowly re-liquify gum, sludge, varnish and carbon deposits from the hard parts in your engine so they can be flushed out of the system. ... Inside the fuel tank, Sea Foam absorbs water, allowing it to be burned up in the combustion chamber without issue.Nov 24, 2020
What does seafoam do to your motor?
Yeah it works for cleaning deposits in your engine's fuel system. It's not a bad idea to run it through a tank of gas every now and then.
What happens when you put seafoam in your gas tank?
Sea Foam cleans and restores lost engine power by dissolving petroleum deposits and residues. Sea Foam lubricates upper cylinder parts for longer engine wear life and helps protect the entire fuel system from corrosion. Sea Foam stabilizes fuel by resisting evaporation, gum and varnish formation.
Sea Foam: What It Is and Why You Should Use It | Reader's ...
https://www.readersdigest.ca › Cars › MaintenanceWhat does seafoam do to your motor?
Sea Foam. Does it really work or just BS? : MechanicAdvice
https://www.reddit.com › MechanicAdvice › commentsPeople also ask
