Say good bye to the diesel 1430
   / Say good bye to the diesel 1430 #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
The PT site now list a gas engine. :(
   / Say good bye to the diesel 1430 #2
That would seem to be the engine. At 132 lbs for the Kohler and Deutz at 400 lbs (adding in 14 lbs for a starter, alt and cooler), they may start adding a counterweight. Or tire ballast.
Other questions, will it now be green, the gas tractor color. With no instrumentation (since that came with Deutz)?
   / Say good bye to the diesel 1430 #7
That's a little over a 20% cut in torque, if it is.
DEUTZ 2011 Series Diesel Engine - Specifications
Small diesels have a hard time meeting emissions these days. How soon until the super charge high torque electric version?:)
All the best,
Peter
...or maybe an eTorque thing like the Ram pickup uses. It wouldn't take much to do since it's an external "bolt on" thing...
   / Say good bye to the diesel 1430 #8
How many new 30 hp gasoline tractors do you see on the market now days?
And there is a reason for that. The pre-emissions diesels were supposed to be good for close to 10,000 with proper maintenance. Doubt that will get that on a air cooled aluminum block gas engine. Then there is the fuel consumption issue. My 65 hp Deutz gets about 1 gal per hour for general usage (not runing a mower or trencher)
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2004 Jeep Liberty Limited SUV (A54815)
2004 Jeep Liberty...
