Say good bye to the diesel 1430
   / Say good bye to the diesel 1430 #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
The PT site now list a gas engine. :(
   / Say good bye to the diesel 1430 #2
That would seem to be the engine. At 132 lbs for the Kohler and Deutz at 400 lbs (adding in 14 lbs for a starter, alt and cooler), they may start adding a counterweight. Or tire ballast.
Other questions, will it now be green, the gas tractor color. With no instrumentation (since that came with Deutz)?
   / Say good bye to the diesel 1430 #7
That's a little over a 20% cut in torque, if it is.
DEUTZ 2011 Series Diesel Engine - Specifications
Small diesels have a hard time meeting emissions these days. How soon until the super charge high torque electric version?:)
All the best,
Peter
...or maybe an eTorque thing like the Ram pickup uses. It wouldn't take much to do since it's an external "bolt on" thing...
   / Say good bye to the diesel 1430 #8
How many new 30 hp gasoline tractors do you see on the market now days?
And there is a reason for that. The pre-emissions diesels were supposed to be good for close to 10,000 with proper maintenance. Doubt that will get that on a air cooled aluminum block gas engine. Then there is the fuel consumption issue. My 65 hp Deutz gets about 1 gal per hour for general usage (not runing a mower or trencher)
Zero Turn Mower (A55853)
Zero Turn Mower...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
