Branson 2810 Leaking FEL Quick Disconnect Solved
   / Branson 2810 Leaking FEL Quick Disconnect Solved #1
Melsman
Branson 2810
One of the issues I set out to solve on my 'new to me' Branson 2810 was a very leaky hydraulic quick disconnect on the front end loader (FEL). I figured it was a bad O-ring, which shouldn't be hard to change... right? If you can find a new o-ring, that is...
The first thing I realized is that the Parker Series 6600 #6603-6-6 female connector on this tractor is not sold in the US (generally) and I couldn't find one at a Branson dealer. This is because it's the BSP thread model. (The male side is the 6605-6-6 - also not generally available in the US.) But I thought I might luck out and find the O-ring (part#JT020115N0674) in stock in the US... but no. But then it dawned on me; the o-ring for the NPT (US) Parker 6601 coupler (#50001-115-0010) should be the same as the o-ring for the BSP 6603 coupler, since they are both 3/8" barrels. And I was able to find the #50001-115-0010 o-ring on-line. So I ordered four and when they arrived, I installed them. They were a perfect fit.
The tricky part when installing the o-rings is to get the o-ring behind the little nylon backer ring (part #411805, BTW). However, with a little patience, the o-ring slipped into place behind the backer ring and sealed the QD properly. No more leaks.
As a note, the o-ring's dimensions are: OD-0.9"; o-ring thickness - 0.1"; material - Nitrile
Melsman
   / Branson 2810 Leaking FEL Quick Disconnect Solved #2
Melsman
Good stuff, thanks Melsman!
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2013 MACK CXU (A52472)
