Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers
   / Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers #1
gatorfarmer
Reidsville, NC
none
Does anyone know if these are the same mowers (Rhino Ag w/Mahindra name)? Reviews. Cant find a whole lot of info on the Mahindra brand.
   / Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers #2
I brought up some images-they look identical. Right down to the shaft of the plastic cover at the gearbox. I would put money on them being the same units.
feel the same, is Rhino Ag a quality brand?
   / Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers #4
They've always seemed to be really good. I have an R300 back blade and it's more stout than any other blades I've seen given the size. Their larger stuff seems built well.
Everything seems to be made by globalists, now. Even things that say "Made in USA" have the disclaimer "With globally sourced parts" or whatever. I'm sure either cutter will serve you well.
I would try and find some manuals or exploded parts diagrams if you want to get deep into the comparing.
   / Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers #5
Rhino is a good brand. I would also check out the bushwhacker and modern ag viper. They make what look to be good 10’ mowers as well.
   / Mahinda F10 vs Rhino AG TS10 Flex Wing Mowers #6
There’s a lesser known company making mowers in the USA 🇺🇸 called Modern AG. Their mowers are hot-dip galvanized and claim to be made in USA. I may be checking them out next time around when I need to replace one of my CX-15’s.
I read somewhere else about a company making American made batwing mowers maybe in TN, but cant find them
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
