Shop Furniture
   / Shop Furniture #1
Larry Caldwell
Elite Member
Myrtle Creek, Oregon
Kubota l3130
A couple years ago I built a deluxe shop with room to pursue all my random hobbies. Thanks to once being a building contractor, and inheriting a bunch of tools from my machinist/blacksmith/farmer dad, I had more tools than I knew how to use. Brother-in-law already had a shop, so he got the big stuff from my dad's shop, and I got all the small stuff like air tools, taps and dies, body and fender tools, an arc welder with high frequency arc stabilization and a TIG torch, etc.
In the last two years I have gone junk shopping. So far, I have collected:
1960s 14" Rockwell drill press that needed the on/off switch replaced - $100
1960s 12" Craftsman table saw, 240 volt only motor with 4 blades, in showroom condition - $100
Recent Harbor Fraught metal cutting band saw - $25
Unknown vintage 6" jointer and 6" planer/shaper mounted on their own wheeled table with 1 hp motor that runs both - $125
Chinese mini-lathe upgraded to metal gears and quick change tool post - $60
Wood lathe - $25
14" wood cutting band saw - $60
20" (!) scroll saw - $20
A friend was cleaning out space in his automotive shop, and gave me a 20' work bench topped with 1-1/4" plywood, that I have shoved up against one wall. For work bench in the middle of the shop, I built a heavy wood 10' bench with four electrical outlets wired to a 12 gauge pigtail.
Does anyone else scrounge auctions and estate sales for tools and shop stuff? The tools from 50 years ago lack the modern bells and whistles, but were built to last and are easy to repair. The planer/shaper needed new bearings, which took me 2 hours and an hour trip to the bearing outfit in town, plus $29 for parts.
I keep an eye on Craigslist too, but most of the prices there are nuts. Auctions are sometimes good. I scored a 55 gallon 3-pt sprayer with diaphragm pump for my tractor for $125 at an auction.
   / Shop Furniture #2
No, not me... :)
I just have three Walker Turner radial saws in various states of rebuild, a Walker Turner radial drill (which is a truly under appreciated tool in my opinion), and perhaps a few, ok more than a few, other antique tools. It is definitely a hobby; I love restoring old tools and using them. Around here, auctions are much better than CL, but it varies. I see lots of older tools for sale locally on CL at fully restored prices for things that clearly need extensive rebuilding. Rather like the local housing market, now that I think about it. That said, I have bought things from CL in other parts of the country and had them shipped, and have met some wonderful people doing it.
I envy all your space.
Thanks for sharing.
All the best,
Peter
   / Shop Furniture
No, not me... :)
Thanks for sharing.
All the best,
Peter
I don't even know what a radial drill is. That's the sort of discussion I was hoping to stimulate with this thread.
Sometimes purchases don't work out. For instance, last year I bought an L shaped piece of 3/8" scrap steel (308#) that I was planning on using as the top to a welding table. I took it for hot rolled mild steel in the scrap yard, but when I got it home I discovered it was hardened plate. I still haven't done anything with it, but mentally I have repurposed it to steel targets and maybe a nice big gong.
I still need a welding table.
   / Shop Furniture #4
Wow, where are you finding deals like that? I'm always checking estate sales and auctions but most I find is junk that they want new prices for.
   / Shop Furniture
All things come to those who wait. I got most of the stuff off of local Facebook for sale lists, and the occasional auction. Some stuff I had to pass on, like the great milling machine for $1500 that was all 3 phase. I don't have the rotary phase converter built yet. I'm still scrounging capacitors, but I picked up a 15 hp 3 phase motor for $25. Freaking capacitors are expensive. I take a VOM with me to the junk yard, and anything not shorted out comes home with me.
There's always good junk around. Have you ever heard of the Post Apocalyptic Inventor on YouTube?
   / Shop Furniture #6
Personally, I like variable frequency drives for converting single phase to three phase.
I think that there is no magic to finding things; it is very random, but my view is if you don't look, you can't find.
Here is my radial drill; it has a 6" quill, with a 31" throat, sixteen speeds, 42" column. This one came with a Morse Taper drill setup that I converted to a chuck. The chucks on these drills fit on a taper that is screwed on, so they can safely take radial force, e.g. sanders, light milling, or even, gasp, hole saws. Not that I would do that, but much safer than "normal" designs. The whole arm slides in and out and is quite rigid.
All the best,
Peter
   / Shop Furniture
A VFD is less practical for a milling machine that has three different motors
   / Shop Furniture #8
Very true...
I know someone who went ahead and bought a three phase surplus generator to cover his shop needs. Mil-surplus.
All the best,
Peter
   / Shop Furniture #9
I converted my Craftsman 17" floor drill press to a 3 phase motor and VFD. I love it, makes it so easy to change spindle speeds when drilling different materials.
   / Shop Furniture
Remember folks, everything in the shop is either hot, sharp, or dirty, and you are the softest meat sack in the place. Wear your gloves.
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
LOT LOCATIONS (A54313)
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
More info coming soon! (A53421)
More info coming...
