Can I use any temperature guage on my Kubota RTV 900?
   / Can I use any temperature guage on my Kubota RTV 900? #1
Kimberlyjn
Rtv 900 Kubota
Kubota Temperature Gauge​
   / Can I use any temperature guage on my Kubota RTV 900? #2
If mechanical (has capillary tube) the sensor mount must be compatible. The sensing "bulb" will have to immersed in coolant. So correct threads, room for sensor.
If electrical, it will have to be same voltage as your machine (12volts) and sensor must be a match (threads) where it will install.
   / Can I use any temperature guage on my Kubota RTV 900? #5
No way, only Nippon Seiki brand ones will work!
   / Can I use any temperature guage on my Kubota RTV 900? #6
I'll add that threads for the new sensor match as well.
Seems that there is SAE pipe thread and metric pipe thread.
Temp sensor I ordered last Jan for my RTV. Worked fine.
More info coming soon! (A53421)
More info coming...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2013 UTILITY VS2RA REEFER TRAILER (A54607)
2013 UTILITY VS2RA...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD72...
