5600 toolcat won’t go forward or backwards
   / 5600 toolcat won’t go forward or backwards #1
Runningwolfjr
Toolcat 5600
Code -50-55. The hydraulics work but machine will not go forward or backwards. After letting sit for a day it work for about 10 mins then quit again.
   / 5600 toolcat won’t go forward or backwards #2
I’m having same issue. Just bought it has 5000+ hrs. Motors good all hyd work. Machine can travel forward and backward by using a toggle switch which was splice in. Shift lever must be put in gear. After that it’s on the toggle switch.
Just got it cleaned, fluids checked, greased an disassembled it to see all wires and controls. Now the trouble shooting part.
So far found mice damage, suspect shifter switch on steering post B.O. mice damage was bypassed and liquid rubber put on burnt and exposed wires.
Burnt wires center bottom frame, been patched.
Still looking for a color coded wiring chart.
So off to test and research.
Ed
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
