Anyone have a mulching kit or just mulching blades on a zero turn?
   / Anyone have a mulching kit or just mulching blades on a zero turn? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I bought a 61" Grasshopper mower with a side discharge, out-front deck. Presently I mow with a 7' rear discharge Woods finish mower. The question regards the side discharge and windowing of grass clippings.
Over the years I've read comments here on the desirability of a mulching kit that forces the grass to stay under the mower deck until chopped to little pieces. As well, I've read comments that say to skip the mulching kit and just get the mulching blades that are almost as effective. This is a new mower and I haven't used it yet so don't know of the windowing potential.
Does anyone use a mulching kit or just the blades that can comment on the effectiveness of either?
   / Anyone have a mulching kit or just mulching blades on a zero turn? #2
I have a 60" Kubota Z326 with a mulching kit added on. The yard looked terrible after I cut it when I first got it. I added the kit and the yard looks great after being cut now. You can see no cut grass or leaves lying around as it mulches them so fine that they blend in. The mulch is good for the lawn as it adds some fertilizer. There are no big clumps of cut grass lying in the yard to kill the living grass.
The only downside is that you must cut tall and wet grass slower as it bunches up under the mower.
tallyho8
Thanks for great info. Very helpful.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #4
I have two zero turns with mulch kits. The mulch kits are great for mulching dry grass and leaves. You can’t cut as fast with a mulch kit.
One thing you can do on the side discharge is raise the deflector up with a bungee cord that way it spreads the clippings out more.
If you don’t run a mulch kit, and you pull the deflector up make at least three passes throwing the clippings to the inside. Then you can throw the clippings back toward the cut areas. That way you don’t throw the clippings into flower beds.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #5
I run gator blades on my ZT. Chops the cut grass into finer pieces and blows them 2X further out the chute. You don't need to slow down in the thick stuff like a mulch kit with chute cover often requires. I also have my chute deflector pulled up so the grass spreads out nicely. Don't do this if you have neighbors or roads nearby. I have neither.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #6
Gator blades work well and lasted a long time for me. I don't like the way they leave clumps so I switched back to high lift blades. I don't want to cut my lawn 2x a week to minimize the clumping.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #7
I have 2 Grasshoppers, a 722DT6 and a 725DT6 with 61"decks and high lift blades. I keep the blade height slightly above 3" for my tall turf fescue lawn. I took the side chute deflectors off shortly after buying each mower, but did try cutting with them on more than a few times. Without the deflector, the grass is blown 2-3 passes away and spreads the heaviest clippings pretty well. Light to medium clippings (most of the year) there are almost no grass clippings visible after I cut (weekly). Without the deflector I can cut right up next to obstacles on either side of the deck, and use the open chute side to stop and rotate the mower sideways over small trees and brush occasionally (along woods, trails, etc). But without the deflector, it does blow the clippings out and up, so on windy days they can get blown back on you. With the deflector, clippings are blown down and in the immediate pass to the side. If you operate without the deflector, it can be dangerous and you must be aware of the blade exposure 1/4" inside that opening. My dealer told be about a guy who cut off a utility pole guy wire anchor stake that way.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #8
I plan to use the discharge cover on the Ryobi when I get it (probably early June). Have always mowed with mulching mowers except for the bush hog.
Plan to remove that deflector from the Ryobi ZT.
   / Anyone have a mulching kit or just mulching blades on a zero turn? #9
Over the years I've read comments here on the desirability of a mulching kit that forces the grass to stay under the mower deck until chopped to little pieces. As well, I've read comments that say to ship the mulching kit and just get the mulching blades that are almost as effective. This is a new mower and I haven't used it yet so don't know of the windowing potential.
The mulching "kit" that I have for my Toro Titan HD 2000 with 72" cut are just mulching blades (3) and a cover plate for the side discharge. I only use the mulching blades when the leaves fall. When I mulch the leaves as soon as possible I don't have to burn.
For regular mowing I use normal blades with the cover plate off. I live out in the country so I'm not trying to have a manicured lawn.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
KSI Conveyor (A53473)
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
