CobyRupert
Super Member
The bore cut mitigates the extent of the barber chair. The section of the tree to split and tear is mostly gone as a result. That is not to say that even with a notch, the tree can still shear.
For the bore cut, there are several things to consider and that is the hinge width, the notch cut and the start of the bore cut itself.
One of the dangers lies at the strap itself as it is a relatively small part of the cut holding up the entire tree. The second danger is leaving the hinge too thick. The third is making the plunge cut above the face cut instead of level with the bottom cut of the notch.
Things happen real fast depending on the size and cast of the tree. The ultimate danger is the sheared trunk that people try to land by cutting the shear itself.
The bore and strap cut I would not recommend for the novice tree cutter and refer to them the Coos Bay cut for the leaner instead.
The bore cut does not mitigate the extent of the barber chair. It only DELAYS the additional lateral stresses (that cause barber chairs) on the “hinge” (or trunk) until the holding strap is cut. If there is no hinge, it will still barber hair (split) because there is no hinge for the trunk to rotate on. It can only split.
I don’t understand why your advocating for barber chairs. They kill novices and professionals. They don’t control the tree as it falls like a hinge does.
I agree, a hinge too thick is a danger because if it doesn’t hinge, it’s like not having a hinge. If you don’t make a face cut you don’t have a hinge. .
As you say, when making a bore cut its location to the NOTCH CUT / FACE CUT is important.
OP demonstrates that not having a face cut results in a barber hair.
