Looking for manuals or info on Essick One Ton Vibratory Road Roller.
   / Looking for manuals or info on Essick One Ton Vibratory Road Roller. #1
3v0
Oklahoma Pan Handle, United States
Kubota BX2200
Just arrived home with an Essick One Ton Vibratory Road Roller purchased at the city auction. It has not been run in 10 years. I removed the main drive chain to move it.
The listing said it has motor trouble, the Wisconsin is not locked up. Found 2 spare plugs on the machine but I think weather took care of any useful evidence.
The data plates are hard to read. Found an add for a similar machine on the internet. An Essick RT30. Mine came with the trailer.
Included these pictures.
This is mine. I have removed some covers on the one side.
The data plates are hard to read. I am going to try making some rubbings off them tomorrow.
Thanks for any and all help with the little beasty. I have been digging the net for some time without much luck.
3v0
Correction to model number. It is a VR30RE. Motor is a Wisconsin AENL maybe AENLO.
Thinking that should be a AENLD. Changed the oil today. Pulled the spark plug and it is a new one. Tried jumping the starter/generator to a battery and no joy. Tomorrow I will buy a rope and see if it will fire up with a gas spray or starting fluid.
   / Looking for manuals or info on Essick One Ton Vibratory Road Roller. #4
Hello, My name is Rod and I also have the exact same roller and also need the manual to get the specs so I know which replacement engine will work as the engine is gone. If you have some suggestions please do let me know at wktkpr@yahoo.com
Thanks,
Rod
Rod I am attaching the parts, operating, and maintenance manuals for the VR30RE.
They made one major change in the unit over its production run. The earlier machines uses rubber blocks on the front drum axles to isolate the body from the shaking drum. The older ones did not. The problem is that the rubber on these early machines will fail if you drive the machine. I have come up with a temporary fix or work around but I would vibrate the drum using it. I have a blog on my efforts to get my machine running Essick VR3RE Vibratory Roller
I fixed one side on mine a drove it long enough to make this video and noticed that the other rubber isolation mount was failing when I parked it on its carrier.
197s Essick VR3RE Running Moving - YouTube
   / Looking for manuals or info on Essick One Ton Vibratory Road Roller. #6
I have recently acquired an Essick VR30RE roller that runs but needs some engine TLC (carb work, points/condenser). While running it the vibrator stopped and I have no service or any other type manual on the roller itself. Is there one available. I noticed a mention of them above. Any help is greatly appreciated. Thanks in advance, Dave.
   / Looking for manuals or info on Essick One Ton Vibratory Road Roller. #7
Essicks VR30 Manual
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
New Holland 1431 Discbine (A50515)
New Holland 1431...
