MF 231S air in fuel system
   / MF 231S air in fuel system #1
fireman4074
MF 231S
I have MF 231S. I replaced the fuel filter. I used the prime pump on opposite of engine to full filter with diesel. I also breed line and call myself getting air out of line. It cranked but it still have air in line. How can I bleed rest of air in line out? It will go died but it will crank after sitting a few minutes. It’s also start blowing blue smoke which it never done that before. The red arrows are lines that bled. Am I missing something? I have video but not able to upload.
   / MF 231S air in fuel system #2
I have a 231s as well. I bought a new filter but have not changed it yet for fear of this same issue.
   / MF 231S air in fuel system #3
You have to bleed all three injectors on the head, crack all three lines, crank engine until you get fuel at all three, then tighten them.
Ok once fuel come out do I need to shut engine off.
   / MF 231S air in fuel system #5
Yes, should have said to stop cranking, tighten the lines, the try and start it. I've had it pick up on 2 cylinders then 3rd picked up after a bit.
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
40' Connex Box, Asset# 32 (CONTENTS NOT INCLUDED - DELAYED REMOVAL, CONTACT SITE MANAGER) (A59076)
40' Connex Box...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
Auger Skid Steer Attachment (A56857)
Auger Skid Steer...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
