Fuddy1952
Elite Member
- Joined
- Apr 17, 2018
- Messages
- 4,332
- Location
- South Central Virginia
- Tractor
- 1973 Economy and 2018 John Deere 3038E
I just bought a 70s Cub Cadet 1250 that didn't have headlights so today I got a used set I ordered. I want to run wires like factory. I assume switch I need is a push-pull SPST and goes in hole I'm pointing to below fuse holder. Used bulbs are good, both GE made in USA (original?). Wire was disconnected but bulbs in parallel as shown, but the big ring terminal...is that grounded & if so where?
Other wire looks cut & stripped. Did that originally have a connector and go to switch?
Where does other switch terminal get power & connected where? Finally, how are wires run?
Thanks so much. If your Cub has lights a few pictures would answer everything.
