Frequency for slipping a clutch a rotary cutter, tiller, etc.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #1
devodad
Dowagiac, MI
JOHN DEERE
Just wondering how often you guys slip the clutch on your equipment. Is this an annual necessity or is it ok to go longer
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #3
I'm going to go out on a limb here and say it's ok to go longer. Mainly because I have no idea what "slip the clutch a rotary tiller, cutter, etc." means. .
Please help me understand what you mean by "slipping the clutch". I can't believe that I'm the only one confused by this question. Apparently, I'm the only one dumb enough to ask . . .
Thanks!
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #4
I slip all mine at the start of the season, every year.
Ohhhhh. You mean manually defeating the friction clutches on each piece of equipment using a pry bar? Sorry. I didn't get the meaning.
I have to admit that I'm seriously delinquent in my maintenance program. The only time I've ever done that is when I was replacing the friction discs and adjusting the spring tension. I didn't realize it was required as a maintenance item.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #5
I slip mine the beginning of each season, they sit under a roof.
If out in the weather, more often may be needed.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #6
it is if you read the instructions that come with the clutch pack. The only one I don't slip is the enclosed one on my disc mower as it's almost totally enclosed.
I'll back off the spring pressure, spin them and retorque the clamp springs.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #7
Wow. I think I've missed the boat on this, but on the other hand, it gives me chills to think about loosening the clutch springs on my hay baler and messing around with it when its working properly. Never mess with a baler that's working properly.
I've never "slipped the clutch" on my haybines, balers, tedders, tillers, bush hogs, flail mower, rakes, etc. Never had a failure due to it being locked up. Was I just lucky?
I'm honestly asking. I don't know. Just didn't realize this was something that I needed to do . . . Any advice?
And just to clarify, I've seen it mentioned in the manuals about checking the clutch by using a pry bar to "slip" it. I've not ever seen any requirement to annually loosen all the springs and move it and then reassemble and check for correct tension. Again, please help me understand exactly what we're talking about here.
Sincerely . . . Thanks.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #8
I loosen mine to make it easier to slip (shorter bar). You get a frozen slip clutch and wad something up in say your square baler, you'll wish you slipped it. Only implement I own without is my NH round baler. Slip (friction) clutches are there for a reason and that reason is to mitigate equipment damage should an event happen that locks the driveline. Protects your pto from excessive shock loads too.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #9
That makes sense. Thanks. I just thought that properly adjusted, those clutches "slipped" a little during normal operation so thy wouldn't be frozen in position. You guys have me rethinking that now.
Thanks for the explanation.
   / Frequency for slipping a clutch a rotary cutter, tiller, etc. #10
I had to replace a fairly expensive 100 hp rated pto shaft because the pto slip clutch didn't give,
spiraled that pto drive shaft and yanked it off the tractors pto breaking the pto coupling in the process.
We got lucky as there didn't seem to be any damage to the tractors pto system. It's been two years and it still works good.
After that we do go through and check all the dry disc style, we loosen the bolts, mark the disks and plates then engage the pto
and disengage and check that tha marks have moved if not put a load on it till it does slip and squeal or smoke then retighten and go to work.
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2008 John Deere 310SJ Backhoe (A59213)
2008 John Deere...
Unused 20x20 Carport With 10' Half Enclosed Side Walls (A55272)
Unused 20x20...
Mini Excavator (A55787)
Mini Excavator...
New/Unused Quick Attach Pallet Forks - 42 in forks (A57453)
New/Unused Quick...
