1949 Ford 8N detergent vs non-detergent oil
   / 1949 Ford 8N detergent vs non-detergent oil #1
scrimmi1
John Deere 950
I'm changing the oil in a 1949 Ford 8N. The existing oil was very dirty and there was sludge in the bottom of the oil drain plug/screen and oil filter housing. The existing oil type in the tractor is unknown. Should I switch to a modern detergent type 15W40 or use a 30W non-detergent oil to avoid breaking down the sludge further and causing possible engine damage?
   / 1949 Ford 8N detergent vs non-detergent oil #3
I would put detergent oil in it and change it very frequently for 2 or 3 changes to flush the sludge out.
   / 1949 Ford 8N detergent vs non-detergent oil #4
Conventional 10W30 oil and filter change.
Tractor will last your lifetime.
   / 1949 Ford 8N detergent vs non-detergent oil #5
conventional detergent oil and if you desired to change just the filter after 10-20 hours.
   / 1949 Ford 8N detergent vs non-detergent oil #6
So, . . . You would do the same with an original 1950's Massey Harris 44 Special gas? Continental 4 banger.
The old gentleman I bought it from almost made me promise to ALWAYS run straight 30.
Maybe gets 10 hrs a year, NOW switch it over to a 10/30 diesel oil??
I'm nervous.
   / 1949 Ford 8N detergent vs non-detergent oil #7
It's your tractor use whatever oil you want, if were me it would be a detergent oil. It will not hurt a thing to change.
   / 1949 Ford 8N detergent vs non-detergent oil #8
I have a old ford 851 with a rear main seal leak. The only oil it gets is the drained oil out of my other vehicles and it really dosnt care.
   / 1949 Ford 8N detergent vs non-detergent oil #10
I'm nervous.
I would. You should be more nervous about getting hit by an asteroid.
2011 FORD F-450 (A50854)
2011 FORD F-450...
2018 GMC Acadia AWD SUV (A48082)
2018 GMC Acadia...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2004 Club Car Precedent Electric Golf Cart (A50860)
2004 Club Car...
