Bobcat324 All hydraulics, tracks, blade dont work randomly...Any idea
   / Bobcat324 All hydraulics, tracks, blade dont work randomly...Any idea #1
mykubota4x4
Member
Kubota B3030HSDC
Bobcat324 All hydraulics, tracks, blade dont work randomly...Any idea.? Its a nice machine with 2290 hrs & have had since begining of this year, changed engine oil, filters but didnt change the hydraulic oil as it was looking good. I did remove the nut at the muffler & saw about 10gms of carbon spill out. Oh i did change the chain case oil. greased quite frequently.Could it be the Hydraulic filter..I have no idea when it was replaced.
Even the tracks dont work along with hydraulics..as if the arm control is up....so could it be just the safety switch or wire or solenoid going bad. I do have some leak at the boom cylinders that i keep topping up the hyd fluids. have to get that fixed. Appreciate inputs.
   / Bobcat324 All hydraulics, tracks, blade dont work randomly...Any idea #2
Since as you say All the hydraulics quit randomly I'd lean towards your thinking of the safety lockout switch going bad or loose wire/bad connection to it
   / Bobcat324 All hydraulics, tracks, blade dont work randomly...Any idea #3
Plus 1 on that.
Thanks Will top up the hydraulics 1st things and see if the problem goes away.
Turns out the right side hand control console that you push down to activate the hydraulics is the issue, there is a bit of play & the console lifts up by few mm & causes to deactivate all controls (safety switch), when pushed down it all works fine. I believe there has to be a switch under thats going bad. I wonder why the console doesnt firmly lock in place(there is a bit of a wiggle).
2006 Pearson Quantum Hale Pumper Fire Truck (A50323)
2006 Pearson...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
377673 (A51573)
377673 (A51573)
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
