Scag stv61v right works as designed the left does not
   / Scag stv61v right works as designed the left does not #1
heyrick
Scag stv61v
Hey there,
I'm a homeowner with 2.5 acres mowed once a week.
My wife moved the mower without releasing the dump valves. I was out of town and she was making an effort to make it happen. The right control lever works but the left doesn't.
I released the dump valves retightened to no avail. I drained the hydraulic oil, replaced the filter and filled with Scag's recommended 20/50 to no avail.
Both steering control rods appear to work as designed.
I ran with the rear tires off the ground. The right side works as designed. The left would spin slowly and I could stop it with my hand with little effort.
Ten years ago I rebuilt one of the hydraulic pumps but I do not remember which one.
Purdy puhlease hook a brutha up with steps to diagnose the cause of the issue.
Than
   / Scag stv61v right works as designed the left does not #2
How fast and far was the mower moved? If towed a distance at speed it is possible the HST got damaged since motor is trying to turn but pump is at zero displacement so oil cannot pass through it. If the tire does not slide the oil had to go somewhere.
Did you notice any improvement after running with wheels off the ground?
Some HST take far more work to get air bled out that others. Running with wheels off the ground is the best way to remove air from the HST circuit
   / Scag stv61v right works as designed the left does not #3
I too question how far it was moved with the bleeders closed.
I havent heard of damaging anything moving a short distance, so this would be a first. And maybe just a coincidence. Maybe that side was on its last leg already and this was the final straw
   / Scag stv61v right works as designed the left does not #4
I agree. I’ve gotten stuck a few more times than I’d like to admit.
Got the tractor to pull me out 10-15 feet. Never opened the bleeders.
No issues whatsoever.
MoKelly
2017 Ford F-750 (A53314)
2017 Ford F-750...
CAT Skid Steer (A50322)
CAT Skid Steer...
Pallet of Fluorescent Traffic Cones (A55787)
Pallet of...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
Sawmill YC-26G W/ Gas Motor (A47477)
Sawmill YC-26G W/...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2022 Chevrolet...
