Plastigage use 'in-frame'
   / Plastigage use 'in-frame' #1
tshep
Gold Member
Richmond, VA
BX23 MLB
I know it's normally used on an upside down engine, journal weight on 'upper' shell so all clearance is at 'lower' shell when torqued.
When the engine is right side up, in frame, what is a good process?
How can I ensure the upper shell is at zero with the journal?
Should I remove all other uppers while checking this one? (Supporting ends, then 'jacking up' a weight near this journal?) (Or just expect the crank to flex enough for contact?)
THX!
   / Plastigage use 'in-frame' #2
Wow, it's probably been 40 years since I've used it.... (on an engine that was upside down as you suggest)
HOWEVER, since it's measuring the gap in there, I can't imagine that it would make a difference what the orientation of the engine/crank may be??
(I'm not a mechanic)
Maybe someone will correct me and I'll be reading with open eyes because I've got an engine that I've debated on doing while engine is in-place which means I would have done the measuring from the bottom so to say.
I'll be intrigued to hear other thoughts but I still can't believe it really makes a difference. After all, a gap is a gap is a gap, no? (if gravity or engine facing down makes a difference then I'd expect there to be other/larger issues to contend with)
It really doesn't, but for that darn (blessed) gravity!
The basic instructions all assume gravity is holding the crank and upper shell down on the engine stand.
In frame gravity breaks things!
And allows space between crank and upper shell.
   / Plastigage use 'in-frame' #4
I’m confused. Are you talking the main crank journals? I also don’t think it matter on the orientation. If it’s on a engine stand and your worried about it flip it over and do it so the engine isn’t upside down.
   / Plastigage use 'in-frame' #5
It won't matter.
What is the purpose for the in frame repair?
   / Plastigage use 'in-frame' #6
Yer over thinking it, been doing in frames for years and always used plastigage without issue to verify what I already knew by using a micrometer. However the bottom line is if you are doing an in frame there is nothing you can do to change the clearance, you have to go back with what came out of it because if your shaft is tapered or out of round then it has got to come out or your wasting your time and money. That is unless you are doing a shadetree patch to get rid of it.
   / Plastigage use 'in-frame' #7
Not familiar with the term "in frame" in the thread title, are you?
   / Plastigage use 'in-frame' #8
"In Frame" generally means the block is installed in the vehicle while crank bearings inserts are being replaced. As one of the other posters said, you have to verify that out of round and taper of the journals are within spec limits or it's waste of time and money.
   / Plastigage use 'in-frame' #9
You don't generally perform and in frame overhaul if you have any knocking or lack of oil pressure problems. It is usually reserved for freshening an engine with excessive blowby or ring wear but otherwise running okay.
You are pulling the head and the pistons and rods in the frame. There is no way to get a mic on the main journals so plastigage is a decent indication if your clearances are too far out of spec. You can generally roll new mains in while you are in there but sometimes you just replace the rod bearings, rings, and do a valve job.
You won't get brand new engine out of it but if the mains aren't damaged you can extend the life of a worn engine. The last one i did for an employer he got another 90K out of it with abusive operators. It was puking so much oil before it was unusable.
   / Plastigage use 'in-frame' #10
To the post, plasti-gage is not so soft as to be significantly deformed by the weight of the crank suspended by the other bearings. ONLY DO ONE JOURNAL AT A TIME!
And to the comments about THE INFERIOR NATURE OF AN "IN FRAME REBUILD.
No, it's not ideal, but if the engine was a runner prior to replacing mains rods and rings. It will go a lifetime again after.
Just be sure to cut that ridge at the cylinder top before the new rings go in, and use the correct size ball hone to refresh the cylinder wall structure. And freshen up those valves and seats!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2007 Western Star 4900 (A56438)
2007 Western Star...
