Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help
That doesn’t sound cheap. Will check the fan and change fluids and cross my fingers. Was my Dads and pretty sure he didn’t do all that was needed. Last complete Service was done by a MF dealer but is not close by. It is a 2002 and has a ton of hours and who knows about the service on this. Thanks for the info
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #12
Dealer serviced usually means it got the cheapest bulk fluid that met the absolute minimum requirements. I had to change out my first dealer service HST fluid after a year due to water contamination. Corrosion on the electrical connectors/fuses has been my biggest issue, no lube was applied to them at the factory.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #13
IM hoping its something simple instead of the spline issue.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #14
A spline failure would cause it to not work regardless of the temperature, so I don't think this is the issue.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #15
That's what I was thinking. Wondering about bypass valve issue.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #16
Keep in mind, there are two pumps.
And, the hydraulics are aparently not working at all.
Can't completely rule out the possibility, that the HST drive pump issue may be related to the shearing of the main hydraulic pump.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #17
they are working until it gets hot...
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #18
Okay, my mistake. Didn't take the time to digest that.
This seems different than any of the other failures.
If we assume the main pump has not failed in some way, I don't know a clear path to explain an intermittent, or heat related failure like this.
I would expect the OP has considered things like: Possibly someone used an unapproved HST filter? Water in the hydraulic oil?
I think I would pull the screen to verify there is no debris, and get a good look at some of the oil.
With two people, one can hold his finger over the opening to keep all the oil from draining, after removing the screen. And another person, checks the screen and the oil.
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #19
Sounds like overheating of the oil. Don't know what the problem is but slowing down and going weak is what happened on our hydraulic CNCs when the oil overheated, usually from clogged/dirty cooling system..
   / Hydraulics quit working after getting hot. Mostly a loss of power to the point of driving backwards to get out of the way. Help #20
Again I'd take look at relief valve or pressure regulator. Whatever the valve called that you can adjust near the underside of the deck height adjust. Can't remember the nomenclature right now.
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
2004 Ford Explorer Sport Trac Pickup (A56858)
2004 Ford Explorer...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
