Kubota KX61-2 electrical/hydraulic issues.
   / Kubota KX61-2 electrical/hydraulic issues. #1
4speed501
1998 Massey Ferguson 231S
I recently purchased a 2000 Kubota KX61-2 mini excavator. This is my first excavator and I am a shade tree mechanic at best. I used the excavator for several hours digging stumps and I smelled something burning. Smoke was rising from the lower right of the machine. I backed up and when I tried to raise the boom, it would not work. I lost all hydraulics to the boom and bucket. I could still raise the blade and drive, but all the functions of the control sticks was gone. When I tried to turn off the ignition, it would not shut the machine down. I then found the engine kill switch (I'm not sure if that's the right name) and stopped the engine. It would not start again. Turning the key has no effect. I haven't had much time to work on it yet. I'm sure some wiring got toasted and that I can repair. My concern is about the hydraulic system. Being a complete rookie at turning wrenches on an excavator, is the boom somehow controlled or powered in some way by the electronics of the machine? It seems like a pretty simple machine, I'm just not sure where to start. Any help is greatly appreciated.
   / Kubota KX61-2 electrical/hydraulic issues. #2
I also just got an older 61-2. For the “controls” to work the left and right “arms” have to be pushed down. Because it was working, make sure the position switch’s within each arm are making proper contact. There are some fuses behind your left foot when sitting, check them first thing.
   / Kubota KX61-2 electrical/hydraulic issues. #3
I’m having the same exact problem. Did you ever figure out how to fix it.
   / Kubota KX61-2 electrical/hydraulic issues. #4
Did you pin point the problem.
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
