Ford 5000 brake rod seal boot
   / Ford 5000 brake rod seal boot #1
fireman4074
MF 231S
I have Ford 5000. I am trying find easiest way to install the brake rod seal boot on this tractor. I caught hell trying get old one out but now new one won’t go in. I tried to press it in but still not luck. Have anyone tackle this issue and can help me out???? Plz
   / Ford 5000 brake rod seal boot #2
Get a piece of pipe that fits it. Maybe run on a grinder a little and start a bevel. On the back corner of seal. Make sure you got all of old one out. Put grease on it. Put pipe on it and smack it.then after install fasten to brake shaft and put nut and washer on. Kinda helps if you have a cheap caliper to see how close it is.
   / Ford 5000 brake rod seal boot #3
I let out some oil to a lower lever than the oil.
Clean that area where the seal must sit with carbcleaner and the fit the seal.
With a clean area that seal will grip and the instalation will be very easy !
Remember to fit the inner part with your fingers and not a sharp tool in its groove .
This is how my seal is made. The silver ring is what not going in. It wasn’t on the old one that I had to scrape off.
   / Ford 5000 brake rod seal boot #5
They all have the metal support in some form or fashion. If your old one didn't come out it still may be in the axle housing. There isn't room for two.
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
40ft High Cube Shipping Container (A54865)
40ft High Cube...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2009 INTERNATIONAL PAYSTAR 5600I FLATTOP SLEEPER (A55745)
2009 INTERNATIONAL...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
