Nova BCRM175 Ditch Bank Mower - 60 day review
   / Nova BCRM175 Ditch Bank Mower - 60 day review #12
Buy Italian, cry once. Or get a good deal on one so you don't have to cry.
I'm almost done crying: I have a degree of confidence that in the longer-run the value of my Nova flail will prove itself; so far I feel I DID get a good deal. One can even get an Italian one/product that has issues: NO factory is capable of 100% QA. Money I "saved" has been used to repair older, quality, equipment (Bush Hog, LandPride): we'll see how well the Nova stuff ages.
   / Nova BCRM175 Ditch Bank Mower - 60 day review #13
I looked at quite a few of the Chinese brands and was ready to pull the trigger when I found the one I ended up buying sitting on my JD dealer's lot. I got it for less than half price because they had it for almost 5 years but it had never been sold. After using it I'm so glad I didn't buy anything else. It's quite a machine.
   / Nova BCRM175 Ditch Bank Mower - 60 day review #14
I bought something that sat for several years and regretted it. It was a Polaris Brutus [UTV]. Has a leaking rear main seal (I believe): not worth the hassle of fixing: saving grace is that it's a hydrostatic trans and there's no concern over drive drain components being compromised by a leaking rear main, such as what one would see with any sort of clutch coupled transmission. OK, I've just accepted it: other than this issue it's done everything that's asked of it- it's been worked hard like everything I have. My point is that things can be compromised from sitting.
One can get less-than-steller equipment from any country. I've got "Proudly Made in the USA" stuff that isn't much better than anything made anywhere else. Japanese cars were once a laughingstock: I remember joining in with a couple of brothers to pick up an early "Honda Car," one with s gear shift on the dash. Some name-brands turn to crap.
   / Nova BCRM175 Ditch Bank Mower - 60 day review #15
Jack, as I've noted to you (privately), the factory needs to step up its game vis a vis QA. I've found loose bolts ([either properly tighten then at the factory OR advise all purchasers to go over and tighten/check EVERYTHING BEFORE initial use] which could have resulted in major failure of the rotor) and a stripped drain plug* (also a minor issue with a keeper pin, an issue that I see isn't unique to my flail): the later isn't catastrophic, but it's caused me an annoyance (and I have been too busy to track down a replacement plug- I also worry that the female threads in the tube might be compromised, in which case I will be looking to try and chase the threads first).
* Upon delivery I failed to go with my instincts that the sealer around the plug was a factory hack job (you said all of them have sealer; the pictures on your website show otherwise- also, no mention of this need in the manual).
I decided to post this publicly because I wish for your company to succeed, I believe that fundamentally you have decent products (but without improvement your sales are going to struggle). I also want this to be a heads-up to others who have just purchased your flails (and other products?): again, I cannot stress this enough: had I not been paying close attention and catching when the rotor bolts broke I would likely have had to have obtained an entire new rotor [and all the work in replacing it]).
I've been in manufacturing (a company that produced world-leading products [read: "the best"]). Getting feedback AND acting on it is what makes a good company a great one. Roller coasters are for amusement.
Thank you, welcome to contact with us if your mower get problem in future, we always supply support.
   / Nova BCRM175 Ditch Bank Mower - 60 day review #16
Yes, you do, and I have. But, my point is, is that there needs to be a focus on QA: it's far more costly to deal with things once they're out of the engineering phase. Again, I'm trying to HELP: I've provide a lot of feedback (privately), with the hopes of it being useful; I wouldn't bother if I believed that you folks didn't care about improving.
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
