How much tire fluid?
   / How much tire fluid? #2
I have a NH 1715 with a loader on it. It has turf tires. How many pounds of fluid should I put in the rear tires?
We need to know the tire size
   / How much tire fluid? #5
They are the 13.6-16 turf tires
This is using the rim guard tool. The weight is predicated on using beet juice (rim guard) as the ballast. Water would be less, and an alcohol mix would be less yet.
Tire Size: 13.6-16​
30 US Gallons
114 Liters
25 Imperial Gallons
Adding the suggested amount will add 321 lbs/146 kgs of weight and fill your tires 75% full
Did you know that Beet Juice is freeze resistant to -35° F, non-toxic, biodegradable, water soluble, and animal food grade safe?
LMC G300JD LOT NUMBER 46 (A53084)
LMC G300JD LOT...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
