JD 4300 Won't lift as much
   / JD 4300 Won't lift as much #11
It sounds like the pump is deadheading when I attempt to lift or curl. It's weird, sometimes it will lift normal and other times it won't.
If its only when you attempt to curl, it sounds like an unseated or faulty quick disconnect
   / JD 4300 Won't lift as much #12
I agree with LD1 on this sounds like a quick disconnect failing. If you feather the joystick in an attempt to raise very slowly will the loader lift? Same with curl / dump. If it works at very low speeds this also points towards quick disconnects failing.
The quick disconnect are definitely seated correctly, do you think it is all four quick disconnects?
   / JD 4300 Won't lift as much #14
It's unlikely all have failed
Is this just curl or lift?
Their is two for each....and if a single one is faulty, it will cause that function not to work. Because they BOTH flow fluid when a function is operating. One allows fluid to supply the cylinder and the other allows return. Block either one (like a faulty coupling) and the system will deadhead
   / JD 4300 Won't lift as much #15
If both curl/ dump and lift / lower are failing is there a chance you have a hose crossed between the two functions? This would cause both functions to fail
when you attempt to raise does the loader lift a little then stop?
Do both of the hoses going to lift cylinders get stiff like under pressure?
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
