Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor
   / Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor #1
Mrsig
Gold Member
Bushnell, Fl
LS MT225 4x4
Dose any one know how to Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor model 400000.
Thanks.
   / Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor #2
Typically, it's just a matter of relocating a spring and changing the location of the throttle cable. The full model number is needed since there's a bazillion different setups. I just did it for a Tractor Supply mini-bike. But I also installed a tachometer and try to keep the RPM no higher than about 4200. If the engine is stock, you can throw a rod in less than a second by over revving the engine.
Any particular reason for your lust for speed on a lawn mower? :giggle:
   / Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor #3
Thanks.
Most governors have an arm the moves as rpms increase. Usually there is a spring that resists the movement. The arm is linked to the throttle plate of the carb. Connect the spring to something to put some tension on it, remove the link to carb, use the original speed control to control the throttle plate directly for engine speed. No need to remove the governor. The tension is so the governor doesn't fly apart. I had one on a Wisconsin engine that the spring broke and the governor was allowed to fly apart, so it did.
Pictures would help. Good luck.
I use the mower to pull a wagon not just to cut the grass and for the bigger loads it need more power that the governor is restricting the motor.
   / Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor #5
More spring tension will allow higher rpms as it prevents the governor's ability to throttle down. The governor's job is to maintain rpm's, when you throttle up, you are pulling the governor's arm to increase throttle. Use a slightly stronger spring, or move the spring closer to the pivot point by drilling an additional hole in the bellcrank. Make a series of holes and you can find the adjustment that works for you.
   / Remove the Governor on 2021 Troy Bilt Super Bronco 46 XP with a 20HP Briggs & Stratton Motor #6
Im surprised 20HP on a garden tractor doesnt have ample power to just spin the tires if hooked to something heavy
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
Freeman Bros 200 Gallon Fuel Tank (A51573)
Freeman Bros 200...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
