Pto shaft spinning when pto shaft is disengaged
   / Pto shaft spinning when pto shaft is disengaged #1
Skylar3788
2012 john deere 8285r
We have a 2012 jd 8285r the pto shaft is still turning when pto is not in engaged. Any reason what might be causing this?
   / Pto shaft spinning when pto shaft is disengaged #2
Does your pto have a shaft brake? if it does, it is generally pressure actuated and so whatever supplies the pressure isn't supplying it and the sloshing of oil in the reservoir (i.e. the rear axle housing) can cause it to turn.
I am assuming it does we got it last year it has an electronic switch to turn it on and off also we can stop the shaft from turning with an object and as we increase the rpm it seems to slow the shaft down and eventually stop spinning
   / Pto shaft spinning when pto shaft is disengaged #4
Sounds like it might need a clutch or control linkage adjustment.
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
ROADTEC RP-190E-3043 ASPHALT PAVER (A52705)
ROADTEC...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
