trouble with 3 point hitch hydraulics
   / trouble with 3 point hitch hydraulics #1
mx842
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I have an old Powerking tractor that I love. I can't remember if it has done this since I've had it of if it just started. I built a grader box to spread and level dirt, gravel or anything else I want to make flat. It's a pain in the back end when you are moving along with a box load of material and need to lift up a little to fill in low spots and hit the lever to raise the box it falls down before it starts to raise. This makes it almost impossible to do any kind of decent job when I am trying to do any finish work.
I know the little tractor has it's limits but I have gotten a lot of work out of this ol girl. Just wonder if this is a normal thing or if it's something that can be fixed. Thanks!!
   / trouble with 3 point hitch hydraulics #2
Not familiar with that tractor, but I'd take a look at the feedback linkage for the 3PH control.
Dont know if you have a service manual...if you do look for anything related to that. If not...maybe try googling for how to adjust the feedback linkage on your tractor
Not sure what feedback linkage is or if there is such a thing on this old tractor.
   / trouble with 3 point hitch hydraulics #4
ITs what makes the 3PH a position control valve.
There would be an adjustable rod attached to the rocker arms of the 3PH that moves as the hitch raises. This gives "feedback" to the valve so it knows when to stop based on lever position. Hence "position control".
Dont know how to explain it other than give you those "key words" to search pertaining to your model or to look in a manual for your machine
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
